Trippling internet speed with pare of AA batteries, ethernet cable and electric tape.
    Re: Trippling internet speed with pare of AA batteries, ethernet cable and electric t
    Originally posted by Spork Schivago View Post
    I do software development. There's a personal project I've been developing for a very long time (I've lacked the time or the skills to finish)...
    I'm curious ... every time I've written something in Java and used the network ... for example, downloading files from an http server, accessing a SQL server etc. ... I've never had to worry about which version of IP I'm using, as the libraries take care of that for me ... I believe it just uses the operating systems layer 6 (I Think) access to the lower layers of OSI ... so what I'm getting at is, wont the OS handle it for the code you're writing?
    Eventually, we will run out of IPv4 addresses.
    Thats a loooong eventually since we technically can give up probably half or more of what we have assigned right now... and I hate IPv6 ... it was a shot gun solution to a problem that had alternatives that they never considered... and they seriously jumped the gun and the project was panic driven and its a convoluted mess! And it was supposed to be the only protocol we use before this year ... that was the prediction ... and yet people only use it in conjunction with ipv4 under the guise of being ready for the master switch to be thrown ... but that will NEVER happen. I mean maybe in an isolated country here or there for some lame reason ... but globally? NO WAY! Not in this lifetime. People are afraid to have public IP addresses so they want less and less of them, not more ... and yet IPV6 has so much address space available ... it would take something like 10 times our population with everyone having like 20 of their own unique addresses before the entire addressing space will ever be consumed... OVERKILL MUCH????
    It is FAR more likely that we will go away from TCP/IP to some new more effecient protocol before we fully switch to v6... tcp/ip is a dense protocol and it has a lot of overhead ... UDP is far better... but what we need is some genius to write the killer protocol that will speed everyone up by like 50% and win us over that way...
    I'm sure it's not as many as some of the other bigger companies (ie, Spectrum, Dish, Direct, etc) provide. Everything's over fiber though, so one point of failure...
    Actually, thats not NECESSARILY true, NOR is it true only for fiber. Any communication network that has no backup links is a network with a single point of failure. The problem with having backup links, is two fold ... material and real estate. Say for example the provider has a hub that serves 10 city blocks centrally located ... now to make that hub redundant, they would need to double the hardware and have a physical path for a second pull of a all the cabling (fiber copper whatever) ... and then you gotta ask yourself ... what am I being redundant for? In case the building gets hit by a train? Or if the electricity goes out ... what disaster am I trying to remain in service over? And it really comes down to the reality that the only way to be really dynamic and amazingly redundant would be to have each home have a link to two different COs in the city so if one goes out, the other picks up in its place ... but thats essentially double the cost of infrastructure for the service provider, so most of them live with the small percentage of risk in possible down time ... and realistically, I've never seen down time for more than two days and in that situation, a truck nailed an above ground fiber distribution hub and knocked it like 30 feet into the desert ... that thing had at least two thousand connections in it ... yet service was back up in less than two days ... I think thats pretty impressive and definitely makes the cost of real redundancy seem way too high...
    The major benefit of fiber is that information can traverse the same distance as copper, but millions of times faster than copper. 15 years ago, we had the technology to simultaneously carry something like a million simultaneous phone calls ON TWO STRANDS OF FIBER! Cant imagine whats out there today... I've seen fiber houses that had fiber optic buffers between the equipment and the fiber in the dirt that went who knows were, and the buffers, which consisted of like 15 feet of fiber looped up inside a box - would have to be changed out every three months because the laser that was driving the fiber was so strong, it would break down the glass in the cable so they had to have that buffer and make it easily replaceable ... every three months ... lol
    The other benefits of fiber ... not susceptible to magnetic interference... lightening ... weather balloons ... northern lights whatever ... your data isn't going to be jumbled up over a few magnetic waves.
    Remember making long distance phone calls back in the day? And you made them after 5pm if you wanted to save money ... but remember how horrible sometimes the connections were and all the static in the conversation to where sometimes you'd have to hang up and try again to see if you get a better connection??? That is a thing of the past thanks to fiber and its resilience against electro-magnetic interference.
    I know almost absolutely nothing about tunneling, so I do appreciate the insight. I have a VPS (Virtual Private Server) that I rent from Linode. It has an IPv4 address and an IPv6 address.
    Sounds like a paid VPN service whos primary goal is to mask your ip address so you can do whatever without being traced ... yes you do connect to their servers over a tunnel ... but being able to do what you want to do through their service - although technically possible ... may not be an option for you depending on their flexibility.
    would I be able to setup a tunnel to connect to my Linode server via IPv6 only?
    Hell, I'd be willing to set you up with a tunnel to my MacPro ... if you need a specific server I could install it in a virtual machine for you... the issue you're going to run into trying to do with with a service provider is the fact that you need something sitting on the other side of the tunnel with v6 addressing etc...
    Just had a thought ... have you considered using a virtual environment to do this in? You can use VMWare or Parallels and you can install multiple virtual workstations or servers and create a completely isolated and virtualized network for those virtual machines ... that would actually be the option that gives you the most control and flexibility.
    I remember the days of the dialup modem, but I was a bit older when I got into them (near the end). My first modem was a 14.4Kbps <snip>. I couldn't imagine a 300 baud!!!!
    Compuserve was ... “interesting” at 300 baud ... a modem I paid $250 for by the way ...
    I do remember downloading a schematic from compuserve of an audio hack someone made for the Commodore 128, which only had three “voices” of MONO audio ... well, with this hack, which required a second SID chip and some other electronics installed on the board, you could have true stereo sound and basically go from black and white to color ... (audibly speaking)
    So I downloaded the schematic, then I bought the components that were listed, I took apart my Commodore 128 and installed all the components per the schematic which was an ASCII graphic! It worked! LOL
    I was only 16 years old at the time.
    I always wanted the source but he wouldn't give or sell it to me (even now, all these years later!!!!).
    Interesting story about the BBS code. Unfortunate he would not release it, I wonder why he was hanging onto it. How did that benefit him?
    I was under the impression that even modern programming languages can do Branching such as the go to statement. For example, I believe in Java all you have to do is create a label, something like :myLabel then you simply use the goto statement two branch to that label.
    What language do you primarily code in? Ive probably got 20 different Java projects that I never finished in my IntelliJ folder ... but sometimes its not about the finished product.
    Today I have almost completed building my own Lithium Ion battery charger with an Arduino ... a project that Ive been wanting to do for a long time ... and not because I need a cheap charger ... but because I want to understand the physics behind recharging certain batteries and I want to add features to the charger that no other charger has nor ever will have ... but today was a milestone as I successfully used a digital potentiometer as the adjustment resistor for an LM317 regulator then fed that through a current sensor to a battery ... and im almost done with the code that will step up the voltage of the 317 via the digital pot, and monitor the current going to the battery so that it can mimic a constant current power supply which changes to constant voltage at the end of the charge until the current drops to almost nothing...
    Its been a fun project and a long time coming! lol
    sigpic
      If you find a WIFI network running on channel 14 in the middle of southeast Wyoming i am not far!
      Follow the white rabbit.
        The US registrars ran out of IPv4 addresses almost two years ago.
        Several other areas, notably in Asia ran out much earlier than that.
        https://en.wikipedia.org/wiki/IPv4_address_exhaustion
        IPv6 was launched 5 years ago.
        https://en.wikipedia.org/wiki/World_...Pv6_Launch_Day
        Worldwide the adoption currently sits at 15%
        Notably in countries with big populations the adoption is much higher:
        In the US and Germany the adoption is at 30% in India it's at 22% and in Japan at 17%
        https://www.google.com/intl/en/ipv6/statistics.html
        Finally the IPv6 space is 340 trillion, trillion, trillion addresses long.
        So your math is off by a factor of say a few dozens orders of magnitude!
          Notice I said we could give BACK more than half of whats been assigned.
          Saying that the registrars have run out is like saying that the dentist office ran out of lollipops ... doesn't mean that those lollipops are gone ... some ended up under someones car seat ... some in some kids toy box ... others ended up in the trash...
          My point is that people are not USING the addresses they were assigned and we could easily force the issue and probably revoke more than half of whats been assigned. Im not sure how long it would take to scan the entire address space, but some hard data could be collected (with known margins of error due to firewalls appearing dark etc.) ....
          In my opinion, the “solution” chosen to solve the “problem” was akin to full time legislators sitting around and find new laws to make so that they look busy. There were better solutions ... and edge hardware has gotten exceedingly good at NAT implementations ... even the old barriers that existed in NAT have been all but wiped out. Hell, updates in DNS have helped too so that there more unique ways to address different pieces of hardware at the same ip address ... I'm just saying its not necessary but it would require them to man the hell up and take a leadership stance on it and get some of those address blocks that aren't being used and never will be ... back ... for re-distribution.
          I'll bet every single one of them are also still running V4 ... and they wont stop either ... see the problem here?
          Now if you wanna tell me that pretty soon, no new networks will be able to get a V4 address block because ICANNA wont issue them anymore ... well then yeah ... they would at that point be forcing the change by being dicks about it. lol
          sigpic
            Saying that the registrars have run out is like saying that the dentist office ran out of lollipops ... doesn’t mean that those lollipops are gone ... some ended up under someones car seat ... some in some kids toy box ... others ended up in the trash...
            That comment made curious, i just talked to a Comcast and an AT&T engineer i know. They both said bullshit. AT&T mobility is operating an ISP NAT to reduce the number of IPv4 addresses they are using because they are short, and Comcast is pushing IPv6 hard, but nowhere near releasing back into the pool.
              Well then I guess thats gospel on the issue ... two of the most heavily used ISPs on the planet having address issues .. hmmm. ....
              Its not those guys is the non-ISP related companies who have the majority of the addresses... SEARS and Roebuck for example ... I guarantee you they aren't using 1/10th of the addresses they have assigned to them ... or Walmart ... or pick any other company besides an ISP who has to actually re-assign IP addresses and will naturally be struggling because everyone else has all the damn addresses... My solution would give a hell of a lot more addresses back into the hands of the ISPs who actually need them.
              Think about it ... the number of NON-Internet service related companies FAR outnumbers the internet service companies ... and yes, they can apply for and get IP addresses straight from the source just like the ISPs do ... there is a shit ton of waste going on trust me.
              sigpic
                IPv4 has 4.2 billion possible public addresses .. according to this site
                https://hostingfacts.com/internet-facts-stats-2016/
                There are 3.2 billion people on the internet in some form (which is more than I thought honestly) ... but there is no reason we should not be able to have a 100 to 1 ratio on public ip addresses ...
                Obviously the way things were established from the get go ... maintaining that level of service means “yup ... addresses are running out and we need more” because people buy internet service (like corporations) and they want those addresses whether they use them or not ...
                And to be honest with you, the only reason I dont like v6 is because Im a network administrator and I have to type those damn addresses in all the time ... you see my beef now?? lol
                sigpic
                  Why couldn’t they have just added a couple of octets to v4 and called it good? Why was it necessary to go from having this many addresses
                  Code:
                  [SIZE="5"][RIGHT]4,294,967,296
                  340,282,366,920,938,463,463,374,607,431,768,211,456[/RIGHT][/SIZE]
                  to THAT MANY ... I mean for the love of all that is good ... we don't even have a word for a number that big ... its 3.4 x 10 ^22
                  few people would even comprehend just how large of a number that is ... and it makes the addresses rather damn large and complicated ...
                  Why you so upset about my dislike of it anyways?
                  sigpic
                    Code:
                    Not sure if you are responding to me or not with that last line.... But anyway, i'm a sysadmin for a local datacenter. We are having issues with IPv4 addresses. I would love if sears gave up some IPv4! We are looking into IPv6, but so little of the customer endpoints support it, it's pointless.
                    I would love to move to IPv6.... Get a chunk of a couple million addresses for pennies! You have documentation for the addresses yeah? We do for out IPv4 even, No problem! But the ISPs aren't pushing it out fast enough.
                      There are a lot of reserved addresses in ipv4 so the 4 billion number is not accurate:
                      - Network and broadcast addresses. Ultimately every time a network is broken down to a smaller chunk, more addresses are 'wasted' to segregate traffic from each piece. Normally a class C network subnet would only have 2 wasted addresses (broadcast and network address), but with my small /29 chunk, this same class C is shared among 32 subnets, which thus means 64 addresses are wasted. Plus people tend to not have machines also serving as routers, so more than 64 addresses are wasted - more like 96 out of 256. That's 32x more wasted IP addresses to make sure people play nice with each other and not do deliberate IP collisions.
                      I think the /29 is probably a fairly extreme case, but that's what it is. /30s are also possible which is even more wasteful.
                      - Reserved address spaces like private address spaces and multicast addresses. Granted private address space is the saving grace for a lot of IPV4 troubles, but it will only go so far. I chose to have static IP so my voice can be heard.
                      I have a dual stack IPV4 and IPV6 setup through 6RD, but unfortunately there are problems with IPV6. There are a lot of people who don't have IPV6 setup properly, and I can't even set up my IPV6 properly because my ISP can't set up IPV6 reverse DNS properly. As far as I know I am fully functional listening to IPV6 requests but since reverse DNS does not work, people reject connecting to my machine... Figures, have to use IPV4 which reverse DNS does work.
                      And yeah, I virtually have a /64 or something like that IPV6 chunk... No way I can use that many addresses...
                        ...so what I'm getting at is, wont the OS handle it for the code you're writing?
                        One of the long-term projects I'm working on is written in C (not C++). The code for the IPv4 stuff is different than the IPv6 stuff. Here's a link that can show you the differences in the code:
                        http://www.lugod.org/presentations/ipv6programming/
                        Yes, we're a long ways away from using up all the IPv6 addresses. But I think the overkill was the whole point. Remember computers back in the day? First, 64K was more than enough memory! Then, Commadore, they came out with computer that had a whopping 128KB of RAM! When MS-DOS came out, I believe (don't quote me), but Microsoft said hey, let's make the OS support an insane amount of memory so we'll never need to worry about it again, let's make the OS support 640KB of RAM! But that wasn't enough as time went on.
                        Same with hard disks. Many times, developers would increase the maximum size hard disk that was supported.
                        With IP addresses, we're seeing more and more "smart" devices. Cellphones, light bulbs, water heaters, electrical receptacles, blu-ray players, televisions, video game consoles, watches, etc that can all connect to the internet. NAT works. I am with you with the IPv6 though on how it was setup. I think it needs a lot of improvements. I didn't know it was just thrown together in a panic, but that makes since. Ever connect to a network that is IPv6 only and fire up something like Wireshark in promiscuous mode? There's so much more "chatter" than there is with IPv4. I couldn't imagine what it'd be like in a large corporation! The congestion must be nuts!
                        ...UDP is far better... but what we need is some genius to write the killer protocol that will speed everyone up by like 50% and win us over that way...
                        It would be nice if we could find a better protocol than TCP/IP. UDP is better for speed, but has it's downfalls as well. With the UDP, there's no error checking. The server sends the packets. If the recipient misses a packet, too bad. There's no way for the recipient to request the server to send that packet again. With TCP, the recipient creates a connection, does all the handshaking stuff, and then asks for the TCP packet. The server sends the TCP packet. The recipient responds and lets the server know it's received the packet. If it doesn't receive it, it'll ask the server to send again until it does.
                        This is just a simplified explanation and it's been quite a long time since I took the CCNA classes, so I might have some of it wrong. If anyone sees something wrong with my explanation, feel free to chime in and correct me!
                        ...Any communication network that has no backup links is a network with a single point of failure...
                        This was my fault. I should have been a bit more clear. With all the residential setups I've seen, there's always one point of failure. What I meant was here, with Spectrum, we've lost television but still had internet and phone. According to Empire, if one service goes out, they all go out.
                        ....The other benefits of fiber ... not susceptible to magnetic interference... lightening ... weather balloons ... northern lights whatever ... your data isn't going to be jumbled up over a few magnetic waves.
                        Even though fiber isn't susceptible to magnetic interference, having fiber for telephone doesn't necessarily mean you won't experience interference though. For example, I call my buddy Jason who has a cell phone. The cell phone is broke. Every 30 seconds or though, he cuts out. No matter where he is. Even when he has full bars. There's a lot of good benefits for fiber and I really want it. I honestly cannot see how it could be worse than Spectrum. I cannot see how any company could be much worse than Spectrum. I just really need the IPv6.
                        It's just a Virtual Private Server. I pay them money each month and they give me access to one of their virtual machines. I can do what I want with it. If it breaks, they fix it for free (if the hardware fails). It's like renting a VPS from GoDaddy, but I feel Linode is a much better company. I decided to install CentOS 7 on my VPS. It stores my website right now for that project I'm working on. Freetime is sparse now and I don't have much time to work on it though. Eventually, my server will act as a central server / database for my program. When someone decides to run my program, it'll connect to my server to communicate with other people running the same software.
                        My Linode server has an IPv4 address and an IPv6 address. Essentially, I'd want it where once the tunnel is setup, for testing purposes, I could, on my personal computer at my house, write software where it tries to connect via IPv4 and fails, but if I try to connect with IPv6, it'll work. Do you understand? I need to make sure when I'm testing the IPv6 stuff that we're not falling back on IPv4 and I just think we're connecting with IPv6. That's all.
                        Just had a thought ... have you considered using a virtual environment to do this in?...
                        Yes, I have thought of this. I actually have a system here that will be essentially a clone of the Linode server. It won't be a virtual server, it'll be a physical server. A development server. cPanel already said they'll give me a free developers account so I can install cPanel on this server for free and not have to pay for it. That way, when I test stuff for the website or for cPanel, instead of just putting it on the production server, I can test various things locally first. If it works well, then I'll move it to the production server.
                        I don't actually want to run a server from my house at this point in time where users will connect to. I want them connecting to my Linode server, no a server in my physical house.
                        Personally, what I think happened, back then, when BBSes were popular, with certain ones, you could pay for the source code for a certain amount of money (maybe 50$ for the BBS, but if you wanted the source code, 100$). However, you were only allowed to modify the source code for your BBS. You weren't allowed to change it and then sell it. I suspect the person of this BBS, the one who won't release the source code, he paid money for the source code and just changed it to make it look like a different BBS and started selling it for profit. I think when it spread across the states to NY (he lived on the other side of the country), they got scared and shut it down, figuring they might get caught. I might be wrong though. I've read a good bit about this developer and when he wrote the BBS, he was young. A person said the first BBS they ran was this BBS software. Some high school kids in Washington (the state) wrote it and where selling it for 50$ a copy.
                        The BBS supports a scripting language, something kinda like BASIC. I find it hard (but not impossible) to believe that a high schooler could write an interrupter, especially one that supports GOTO statements. That's not the easiest thing to do. I've tried. There's a good bit to it. I've talked to people who could write this scripting language. Computer scientists with a PH.d, for example. They said they'd be willing to do it, but because of the work involved, something like this would cost me around 10,000$.
                        What language do you primarily code in?...
                        I primarily code in C. And languages like C do support goto statements (although a lot of good programmers will look down upon programmers using goto statements). The problem isn't the programming language that I write the BBS in. The problem is the BBS itself has a built-in programming language. You customize the BBS by modifying these .MNU files. The .MNU files are a bit like a BASIC file. You write code in those .MNU files. Stuff like
                        Code:
                        if %userlevel%==9 goto sysop
                        if %userlevel%==8 goto cosysop
                        Using goto's in a programming language isn't hard. Writing a program that can interrupt a language is a lot harder. I've purchased some books to help with this. One is the infamous red dragon book (Compilers: Principles, Techniques, and Tools). This is a programming book that's designed to teach you how to write compilers, interrupters, etc. Stuff like Python would be an interrupted language. That means the source code doesn't get compiled. A program interrupts it. I sometimes refer to these as scripting languages. Essentially, I need to write my BBS software so it's a BBS but also something like Python or BASIC or whatever. I compile the code, but it loads text files that have a custom language inside and the BBS software can understand and does stuff differently based on whatever's inside that file.
                        Do you understand? I can PM you and send you more details and examples if you want. I know it's a bit of information to take in and I'm not doing the best job explaining all of it.
                        -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                          I think one of the problems with IPv4 was like in Deposit. The PCs had public IPs for whatever reason. We did business with banks and FedEx, but mostly big banks. Banks that small banks do business with (ie, Juniper). Class C was too small, Class B gave us waaayyy more IP addresses than we'd ever use. But I don't think there was away to get a partial class B network. I don't think they could have asked the US registrar's for 1,000 class B public IP addresses, for instance. I think you need to get the full 65,536 addresses. That's a lot of wasted IPv4 addresses!
                            Even if companies had to give back the IPv4 addresses they weren't using, that's still a temporary solution. Eventually, we'll be back to where we are now, with running out of IPv4 addresses. It might take a good amount of time, but I think we just need to sit back down at the drawing board and either revise IPv6 or, like you suggested earlier, come up with a better protocol all together (I'm thinking something like Spork/IP, that sounds good!)
                              Originally posted by eccerr0r View Post
                              ...I have a dual stack IPV4 and IPV6 setup through 6RD, but unfortunately there are problems with IPV6. There are a lot of people who don't have IPV6 setup properly, and I can't even set up my IPV6 properly because my ISP can't set up IPV6 reverse DNS properly. As far as I know I am fully functional listening to IPV6 requests but since reverse DNS does not work, people reject connecting to my machine... Figures, have to use IPV4 which reverse DNS does work.
                              Isn't reverse DNS mainly used for mail servers and anti-spam techniques? Are you running some sort of mail server?
                              I had some issues setting up IPv6 on my server originally, but smart people at cPanel helped. Turned out I wasn't doing everything properly. However, I kinda cheated. I used cPanel (a kinda graphical sysadmin tool). I didn't set it up through the console, I set it up through cPanel.
                              GoDaddy originally had IPv6 all setup and in place, but they got rid of it, saying not enough users were using it! I thought that was the stupidest thing they could do!!!! For what it's worth, with GoDaddy, you cannot setup reverse DNS. It's because they have this system in place that's supposed to prevent people from sending massive amounts of spam. All outgoing mail goes through one of their relays. That's why when you do a reverse dns lookup on a GoDaddy server, you see something like ip-<ipaddress>.secureserver.net, instead hostname.domain.com
                              I want to say even if you rent a dedicated server from them, you don't have the ability to setup reverse DNS. That's one of the reasons I moved away from them. The other, being the IPv6 stuff.
                                - A class A is a /8, a class B is a /16, and a class C is /24. As seen in my case I have a /29 partial C so it is possible to break a network outside of an A, B, or C class. However every break, as said, will have more overhead addresses wasting more addresses, so it's a tradeoff (plus the breaks need to be an integer power of 2). To better save IPV4 addresses everyone needs to be on the same and huge subnet, and people know what messes comcast has to deal with.
                                Because of the inefficiencies and address space segregation necessary, there's no way to constantly dole out ipv4 addresses. V6 is unfortunately needed and I will not stand behind NAT even if I get hundreds of hack attempts every day.
                                - There is indeed more chatter with IPV6, but that's because it's autoconfigure plus the additional bytes for specifying the addresses - and it's only on the local segment. But still, the amount of chatter packets is not that large - it's mainly the router advertising itself to all on that segment. The endpoint machines do not need to keep chatter the router unless it has real data it needs to route out.
                                - UDP does not mean faster than TCP. Both are running over IP so there's always that limit, but the main difference is that TCP holds state and "guarantees" packets transfer in order. UDP on the other hand, does not give any guarantees to your packets.
                                Why is it "faster?" The header overhead does not sum up to be a huge amount, however, there's no need to wait for an ACK every packet for UDP. The cost of UDP is that each individual program needs to now keep track of packets received. Not only that, UDP packets can be duplicate, delivered out of order, or even dropped - so you have to take care of these cases. Plus the sender can silently disappear and the receiver needs to deal with this case too, versus the sender just being slow or not have much data. It's much more trouble than claiming it's "faster".
                                In fact UDP could be slower on most WAN except those extremely reliable networks. Most people can't even gauge this because TCP hides all the network garbage that occur, actually fairly frequently - people (and software writers) don't typically see any wrong order, most of the lost, or duplicate packets.
                                Plus there are those ISPs and NAT routers that automatically drop UDP routing information after a while because they can't tell when you're done - when FIN packets for TCP are loud and clear - just to make sure they don't get completely overwhelmed with holding too much state. You'll really learn to hate these routers. I suppose there's a reason why NFS was rewritten to allow TCP connections though historically it's been completely UDP.
                                - IPV4 and IPV6 software necessarily needs to be written differently as your userland code now needs to handle 128 bit IP addresses versus the 32 bit addresses in IPV4. However the API, at least for Un*x, is still very similar. Writing code that listens to both IPV4 and IPV6 means you'll have some duplicate code that needs to be maintained separately.
                                Yes I run my own home mail server. For now I'm stuck with using IPV4 mail because reverse V4 DNS works fine. I had to explicitly disable IPV6 because googooeverywhere insists on using ipv6 and not fall back to ipv4 when an address has both A and AAAA records. Maybe someday my ISP will fix reverse V6...
                                Godaddy was actually tunneling IPV6? That would have been neat, then again Hurricane still has ipv6 tunneling for the public? I happen to have 6RD tunneling with my ISP so that should work out better, except they don't know how to do V6 PTR records.
                                  I’ll bet every single one of them are also still running V4 ... and they wont stop either ... see the problem here?
                                  It sounds to me like you have not read the news in the last few years.
                                  IANA ran out of address space in 2011.
                                  It does not mean the world is ending but just like what has been stated before the whole 32bit IPv4 address space (4.2B addresses) is not usable.
                                  The actual number of usable addresses is something like 3.7B, but that also is a high number as you can't perfectly distribute out those addresses.
                                  And it creates also another issue which is routing related: before you could look at an IP and know which country it belonged to.
                                  Not anymore, the address space is so segmented that addresses very close in numbers can be on different continents.
                                  This makes routing tables very big and complicated.
                                  This is what IPv6 is here to solve, it's to make the address space utilization easier, not for you but for the routers that do the actual work.
                                  https://en.wikipedia.org/wiki/IPv4_a...tes_and_impact
                                  https://www.iana.org/assignments/ipv...ress-space.xml
                                    I know this as subnetting. My understanding was the main reason you'd subnet a network was to cut down on collisions. Are there other reasons?
                                    ...- There is indeed more chatter with IPV6, but that's because it's autoconfigure plus the additional bytes for specifying the addresses - and it's only on the local segment. But still, the amount of chatter packets is not that large - it's mainly the router advertising itself to all on that segment. The endpoint machines do not need to keep chatter the router unless it has real data it needs to route out.
                                    I've done things on one of my servers to try and cut down on some of the chatter. Stuff with IPv6 ICMP packets (I can check into what I did, if you really care). I did this at a firewall level, to try and prevent abuse. It's good to know the amount of chatter is not that large.
                                    Why is it "faster?" The header overhead does not sum up to be a huge amount, however, there's no need to wait for an ACK every packet for UDP. The cost of UDP is that each individual program needs to now keep track of packets received. Not only that, UDP packets can be duplicate, delivered out of order, or even dropped - so you have to take care of these cases. Plus the sender can silently disappear and the receiver needs to deal with this case too, versus the sender just being slow or not have much data. It's much more trouble than claiming it's "faster"....
                                    I wasn't looking at all that. I was just looking at the header and the handshake stuff. Thanks for refreshing my memory! I tried writing a program for the PS3 once that used the broadcast address. By default though, the firewall on Ubuntu (which I don't run anymore, but did at the time), was blocking it and I could never figure out how to allow the traffic through! I figured if I was having this much trouble with it, then general users probably would as well. I was sending UDP packets to the broadcast address. The idea was the PS3 was the server and the Linux box was the client. I was trying to get it where the PS3 didn't need to know the IP address of the Linux box at first. The PS3 program would send a UDP packet on the broadcast address. The Linux box would look for this packet, once it found it, it'd send back a packet with the IP address of the Linux box, and then it'd establish a connection.
                                    I'm sure it was just something stupid I was doing. I'm still not an expert at iptables, even though I've learned a lot over the years.
                                    ... IPV4 and IPV6 software necessarily needs to be written differently as your userland code now needs to handle 128 bit IP addresses versus the 32 bit addresses in IPV4. However the API, at least for Un*x, is still very similar. Writing code that listens to both IPV4 and IPV6 means you'll have some duplicate code that needs to be maintained separately.
                                    Yeah. Maybe even quadruple code. One for IPv4 in Linux, one in Windows, one for IPv6 in Linux, one in Windows. With this Weller preheater I got, there's a serial port on the back. I contacted Weller and they gave me the protocol information and I can communicate with it with a custom program I've written. I wanted to release it open source but have a Windows version and a Linux version. I didn't want two separate programs though. And I didn't want to have a whole bunch if #IFDEFs for Windows and Linux. I found a third party C library that really helped. The library takes care of all the serial stuff so I don't have to. Maybe for my BBS program, I can just write a small library that does all the dirty work. That might be the way to go. Or, because the code for IPv4 and IPv6 is very similar, maybe I can just have a function for the IPv# specific stuff, and then where the code is the same, a different function or something. You know, like
                                    Code:
                                    int initiate_ipconn(int ip_ver) {
                                      if(ip_ver==4) {
                                        /* Do IPv4 specific stuff */
                                      } else {
                                        /* Do IPv6 specific stuff */
                                      /* Do IP version independent stuff */
                                      return 0;
                                      ...And it creates also another issue which is routing related: before you could look at an IP and know which country it belonged to.
                                      You're saying with IPv4 addresses, you cannot tell which country the address belongs to now? Or are you saying that's with IPv6 addresses?
                                      Thanks.
                                        IPv4, been like that for a long time now due to how segmented the net have become.
                                          Oh I'm quite familiar with subnetting .. And very vew corporations would subnet their public addresses ... what would be the point? Their Internet connection terminates at a router then at a firewall but at the router, natting can start, so breaking up their assigned network addresses makes no sense really. If they have multiple locations, the ISP will assign their own subnetted blocks of addresses to each location. So if anyone is sucking down broadcast and network addresses, it would be ISPs ...
                                          I've often wondered what class of addresses the main authority assigns to ISPs and what not ... Ive only ever worked with 24 bit masks have only gone higher than that in the private address space.
                                          Thats a curious statement ... what do you mean by this?
                                          The issue of reverse DNS should be with the company who hosts your DNS record ... Godaddy in my case. The ISP has nothing to do with it, unless their DNS servers are also the root servers to your domain name. If so, just switch to someone else for record hosting. I think google does it for free ... you still pay whatever company you pay now for the domain name, but you go into your record and set the IP of whatever name server you are going to use and then all hits to your domain will start with the new name server... and I'm sure I can say with confidence that google has RDNS working with IPV6.
                                          To find out who hosts your record you can go to a command prompt and do an nslookup against your domain name with a soa query type.
                                          The number of possible addresses in v6 is mind boggling...
                                          sigpic
