Ethernet over fiber
  • rs232killer
    • Feb 2015
    • 89
    • Portugal
    Ethernet over fiber
    Hi
    I bought a nice gigabit router with 2 fiber ports, the respective transceivers , 10mts of LCLC cable and some pci-e emulex LPE1150
    now, the catch , its the first time that i touch fiber stuff, in my grunt mind it should appear a new nic on windows and boosting my lan and file transfer to 2gb but it doesnt
    appear a HBA port no NIC, anyone have some experience on this field before i go swimming on pdfs and datasheets ?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Ethernet over fiber
    Originally posted by rs232killer
    Hi
    of course it should show up in windows as another nic... does it not?
    how are you testing throughput?
    • rs232killer
      • Feb 2015
      • 89
      • Portugal
      Hi , nop , no new nic card just some Emulex lightpulse HBA- Storport
      ty for your quick response
      • rs232killer
        • Feb 2015
        • 89
        • Portugal
        the switch show on the manage panel link down, this emulex have bios config, going to reset to default now.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          in device manager?
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            wait a minute... i think the card you ordered is for storage, not networking.
            HBA and NIC are not the same.
            • rs232killer
              • Feb 2015
              • 89
              • Portugal
              rrrr some pic from device manager
              but probably your are 100% right
              i have 3 nice cards to trash xd
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                What about this?
                http://www.ebay.com/itm/MNPA19-XTR-1...cAAOSwFqJWsPch
                • rs232killer
                  • Feb 2015
                  • 89
                  • Portugal
                  ouch a bit expensive for home fun
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    I changed link, it's $18 now, hopefully a bit more reasonable
                    • rs232killer
                      • Feb 2015
                      • 89
                      • Portugal
                      much more but still missing shipping costs to Portugal
                      that card appears as a nic ?
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        http://www.ebay.com/itm/LOT-OF-2-MEL...3D131634470127
                        This is another seller in the USA with teh same item (just 2 pack) maybe they offer shipping to Portugal?
                        My friend who does fiber stuff for a living says that card is NIC not HBA.
                        • rs232killer
                          • Feb 2015
                          • 89
                          • Portugal
                          now i know hard way, well must order NIC plain and simple and run from CNAs HBA and all that
                            • 31017
                            what's the router make/model?
                            • rs232killer
                              • Feb 2015
                              • 89
                              • Portugal
                              gsw-2494
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                That's a layer 2 managed switch not a router.
                                What transceivers have you got ?
                                It's doubtful you will see much of a speed difference between the fibre and the gigabit ethernet ports.
                                • rs232killer
                                  • Feb 2015
                                  • 89
                                  • Portugal
                                  Avago AFBR-57R6APZ EMC 4.25Gbps 4Gb Fibre Optic SW 850nm SFP Transceiver Agilent
                                  well its more fetiche than results if you know what i mean
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    Like other people said, that's a switch, not a router.
                                    Also, you should mess with fiber only if you're going to go to 10gbps or if you need to connect the switch to something further away than the maximum of 105 meters.
                                    The two SFP ports (shared with rj45 ports 23 and 24) only support 1 gbps according to the manual so why bother with fiber?
                                    The router supports port trunking so you can buy an Intel 4 port network card or a couple of 2 port network cards and use 4 regular cat5e cables between your computer and the switch to go up to 4 gbps.
                                    Here's examples of such cards:
                                    1. http://www.ebay.com/itm/Intel-Pro-10...kAAOSwZG9Wio6K
                                    2. http://www.ebay.com/itm/Intel-Quad-P...8AAOSwll1WvMAs
                                    3. http://www.ebay.com/itm/IBM-INTEL-PR...sAAOSw3ydV3fmo
                                    Lots of dual or quad port network cards here: http://www.ebay.com/sch/i.html?_from...00+pt&_sacat=0
                                    But anyways... you'll basically have 4gbps between the computer and the switch, from switch to your internet router/cable modem you'd still have 100mbps or 1gbps.
                                    If you want strictly for lan transfers, you would have 2-4gbps (depending on what card you use) between you and the switch, but the other computers would still be limited to 1gbps, unless you buy new cards for the other computers as well (and configure port trunking for each computer).. second hand cards are cheap on eBay so I'd say go for it.
                                    If you manage to do the trunking, i suspect you'd still have a bit of a hard time reaching 4gbps between two computers - you may have to increase read and write buffers on the network cards to the maximum, number of buffers raised to the number of your processor's cores, configure jumbo frames on your network card AND the router AND the other computer to the maximum size so that data packets will be larger than the default ones and then as long as the hard drives manage and your processor is fast enough, you'd have up to 2-4gbps
                                    It's been a long time since I researched this, but you may not even need to do port trunking to get more than 1gbps... I've seen some videos on LinusTechTips about using SMB 3 to aggregate links transparently
                                    Here's a couple of videos they have (at a very brief search through their list) :
                                    https://www.youtube.com/watch?v=K4VnWQPW-f4
                                    Quadruple Your Network Speed for $100 with SMB 3.0 Multichannel!
                                    ... the older ncix video he mentions at the start of the video above: https://www.youtube.com/watch?v=ycbq...&feature=cards
                                    https://www.youtube.com/watch?v=D03t890dKTU
                                    10 Gigabit Networking - I wanna go fast. Really, really fast. <-- but the card themselves are still expensive, even from eBay
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      Here's the manual for your switch.
                                      https://cdn.badcaps-static.com/pdfs/...d5cebb8817.pdf
                                      It shows support for 1Gbps SFP transceivers.
                                      Have you tried yours in the switch to see if it's recognised ?
                                      • rs232killer
                                        • Feb 2015
                                        • 89
                                        • Portugal
                                        Hi
                                        i thought it was 2gb ... so it wouldnt be faster than my gigabit connection
                                        mariushm , will review the info that you posted , it seams a good option those quad channel or 10gbs fiber...
                                        diif, its reconize the transceivers but @ 1gb wich now i see its normal
                                          Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 08:58 AM
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • gsan33
                                          Equipmet to trace Ethernet signal
                                          by gsan33
                                          I have Avaya 9641G IP Phone wich reports "No Ethernet" on the screen during initial start. I have intention to trace an Ehternet signal from the very input RJ45 jack throuth the phone mptherboard to the Broadcom communication CPU input pin.
                                          Need youe advice how to: first I have suggested to buy an oscilscope, but not sure what to select, the pro version may become too expencive, and basic version may not capture high frequesncy signal. I really don't what to spend a fortune just for the pleasure to see the Ethernet frames. I also considered to measure just an AC voltage at the...
                                          03-07-2023, 02:04 PM
                                        • orfeous
                                          Xbox 360 Elite Ethernet not working
                                          by orfeous
                                          I've got a Xbox 360 Elite with a Jasper V1 or V2 PCB as far as I know. 150W PSU and rated for 12.1A and the Xbox has the MFD 2009-10-14
                                          Issue is that there was a lightning outside and now the ethernet does not work. Power cord was unplugged. Only ethernet cable was plugged in. The router and some other stuff died.
                                          No error codes. Xbox seems to work as I should. When i plug the ethernet cable in nothing happens. Dashboard only tells me to plug in a ethernet cable. Or i don't remember.. if Ethernwr maybe was greyed out since it didn't recognize a connection.
                                          02-22-2023, 11:39 AM
