Wireless Config error!
+ More Options
Posts
  • ivtec
    • Dec 2008
    • 1967
    hi guys need help, i can't get wireless secure wep at all,i had it but one of my laptops did not get the wireless in linux so i tried to do other secure settings but now i can't get it at all
    i do a router factory default and then i add the secure #'s and apply i get this error check attachment.
    this is a Toshiba WRC_1000 connected to TG862 Aris
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Wireless Config error!
    Probably because you're adding a value that's not a mac address.
    • ivtec
      • Dec 2008
      • 1967
      What value should i add? thanks Mad
      • ivtec
        • Dec 2008
        • 1967
        What values should i add?
          • 30963
          look at the example above where you entered the data.
          you forgot the : between each pair of characters.
          • ivtec
            • Dec 2008
            • 1967
            do you mean exe: 12:45:78: and son on?
            and when i config on the Pc i have to put same thing?
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              Yes, you need to add the double colons for every mac address, to add multiple mac addresses you add a comma at the end of each mac address with no spaces.
              • ivtec
                • Dec 2008
                • 1967
                Thanks professor: and this config; see pic attach.
                Access Control Mac address; enable or disable
                Wep key Disable or Enable
                802.1X used or not Used
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Are you trying to set up a whitelist of mac addresses ?
                  If so then enable Access Control Mac Address and enter the mac address of all of the wireless devices. Whilst a little more secure than just using wep, it's fairly easy to subvert, and a pain to keep adding mac addresses every time you want to connect a new device. You will disable 802.1x and distribute wep key.
                  • ivtec
                    • Dec 2008
                    • 1967
                    i don't know the difference,i just want the easier one and simple one,i've been trying to make a secure wep trying different #s different config and get nothing i have to keep the open connection otherwise get no wireless on my old linux and win Xp computers,
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Disable 802.1x and i believe the page will change enabling you to set the wep key.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Here is the manual.
