Unbricking Vigor AP
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Unbricking Vigor AP
    Good day.
    I'm posting this to help other people.
    If you have a Vigor AP with some kind of a software issue or just with an unknown admin password and disabled reset button, here is how you can flash a fresh firmware.
    Download the firmware from the vigor's website and extract it somewhere.
    Download TFTPD64 or other tftp client with file push.
    Connect to the unit with an ethernet cable and set your client IP address to 192.168.1.10 (just not .1 or .2).
    Start TFTPD64, go to tftp client tab. Select the server interface with the above IP and then enter:
    host 192.168.1.1 or 192.168.1.2 (if one does not work, try the other)
    port 69
    local file - the firmware file (extension .all)
    Click PUT
    Press and hold the reset button on the vigor and turn it on (release the reset button after few seconds).
    If everything goes fine, the unit will enter in TFTP recovery mode and will start a tftp daemon on .1 or .2 and tftpd64 will be able to successfully push the new firmware file.
    This will also enable again the reset button and then you can do a factory reset.
    My case was a VigorAP902 with an unknown admin password and disabled reset button.
    Connected to console (baud rate 115200), unfortunately all inputs are disabled or password protected, but was able to see that the recovery mode is a tftp daemon and on which ip it runs.
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • ictc
    Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
    by ictc
    I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
    Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
    The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
    02-25-2025, 12:15 PM
  • kotel studios
    ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
    by kotel studios
    Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
    Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
    I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
    12-14-2024, 10:48 AM
  • MyBrainIsAStrainer
    Asrock H87-Pro4 Rev. G/A 1.04: Power cycling on reset only
    by MyBrainIsAStrainer
    Hi!
    I have a weird one for you. I have a H87-Pro4 from Asrock that power cycles. But only when you do a restart after it was already running!
    Symptoms in detail:
    1. I switch off the ATX PSU for ~15-20 seconds, then switch it back on again.
    2. I press power button. The board boots without issues.
    3. I can shut down the board any way I want (via OS* menu, or pushing the power button - either in the OS or the boot manager).
    4. Push power button again, board boots fine.
    5. This shutdown/powerup can be repeated multiple times without problems.
    6. BUT: If I do a restart instead
    06-25-2023, 02:44 PM
  • masterm
    JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
    by masterm
    TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
    Problem with TV:
    - Netflix stopped working so i tried to do factory reset from the TV menu.
    - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
    - After waiting for some time, the TV went into a boot loop.
    - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
    04-30-2024, 03:03 AM
