Foundry edgeiron 4802cf - quiet down.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Well, it has three little fans and they are really annoying. The unit does not get so warm. Will I need a resistor and which kind?
    Thanks.
    Also why when I put it in Full Duplex the activity indicators don't blink. How do I set it to still show me activity?
  • mariushm
    • May 2011
    • 3799
    Re: Foundry edgeiron 4802cf - quiet down.
    Find out what voltage the fans run at and what current they need for full speed. It should say on the label.
    Let's say the label shows 12v , 0.25A
    V = I x R (ohm's law) ... hence I = V/R or R = V/I
    So R = 12/0.25 = 48 ohm ... that's the load of the fan
    If you want to reduce the voltage appearing on the fan, you need to drop some of it on a resistor.
    Let's say you want to drop the voltage to 7v , that means 5v have to be dropped on the resistor.
    The fan's new current will be .. V = I x R => I = V/R = 7/48= 0.145 A.. just to make it easy let's say 0.15A.
    So now the resistor has to allow at least 0.15a through, to the fan, and drop 5v on it:
    V= I x R , R = V/I => R = 5v / 0.15 = 33 ohm
    Power dissipated in resistor is computed with formula P = I^2 x R
    So P = 0.15x0.15x33 = 0.74 watts.
    So you'll need a 33 ohm 1 watt resistor (or higher, a 2w resistor will stay cooler)
    Now this math is just for one fan, and to slow it down to 7v... if you have all three fans in parallel, add the currents before doing the math.
    And I'd suggest lowering their voltage just to about 9v, maybe they'll be silent enough.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I'll check tonight and post here, thanks!
      • emil_t
        RTX3090 working fine but fans not spinning
        by emil_t
        Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
        04-12-2024, 06:54 AM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        Need help to replace burned resistor in 350w atx psu
        by mikey5791
        Hi to all forum members,
        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
