Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
  • holomike
    replied
    Re: Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
    Thanks for the quick replies selldoor. I am not walking away from this thread, so dont be offended by my slow replies. I am appreciative of the help available here. After my post yesterday afternoon I was boxing up that main board for rma but wanted to try it one more time to make sure I had the ribbon cable for the controls in correctly and verify that it was not working before sending it back. I have verified that is is junk to me and being rma'd. After I put everything back together carefully checking that the 2 cables are carefully aligned and in deep as they can be, I have had the monitor on for quite some time now and it still has not malfunctioned. The 6 bulbs produce a tremendous amount of heat that rises to the top vents right where the CN1 and CN2 cables are. I guess that is why the cables are becoming heat sensitve. I will wait and see what happens. I should get a new dmm on monday or tuesday and I can start checking voltage regulators next. Does this sound like it could be a voltage regulator issue at all? I am trying to learn all I can about this stuff. This is my first attempt at fixing a monitor and I am starting to feel like im just shooting in the dark. BTW no i did not clean CN2 as well as CN1 because when I noticed that tapping and sliding my finger on cn1 was bringing picture back I did not notice it when doing the same to cn2. I will clean it next time i take it apart.
  • selldoor
    replied
    Is there a cable in CN2 - have you cleaned that?
  • holomike
    replied
    I don't believe the bulbs are actually flickering. The LCD panels pixels are what appear to be fluctuating between vibrant colors and blackness(distinct edges like pixels turning off). Sometimes it looks like aurora borealis lights with a trace of light visible around the edges of the panel. Tapping on the side makes the picture come back momentarily. I did open the panel up to look at bulbs and I couldn't see anything physically wrong. No burned looking areas on bulbs or bulbs sockets but I'm not sure if visual inspections mean anything. I will turn it on tonight and look at the bulbs carefully when it starts. I can post a picture of the screen too if that would help to better understand what I mean by flickering.
  • selldoor
    replied
    Hi holomike - when it is flickering can you hear any noise from near the inverters
    I am thinking it might be a faulty bulb or the wiring to them- If te set has done a lote of hours a bulb could be on its way out or the insulation going on one causing it to arc.
    Can you get into the ends of the bulbs to check.
  • holomike
    replied
    My L2410nm has been acting up now. This thread has helped get me started on repair. My screen was flickering and not starting correctly until it warmed up, did it for a week or two before it just kept flickering. I found 3 of 4 capacitors on the inverter board bulged. Changed them and it did nothing. So i got a used working inverter board on ebay for 12 bucks thinking a ballast resistor might be bad(I didnt know how to test). That didnt work so I got all new capacitors for the power supply and even resoldered the transistors cause the solder looked like it might be cracked. That didnt work. The pcb around the transistors looked like it may have been cracked and damaged and brown so I bought a new psu. That didnt work. So I figured im in this far I might as well replace main board, thats got to be it. The new main board doesnt seem to be recognized correctly, I hook it up, plug in power and before I press power the monitor turns on on its own, says 'no signal' then shuts off after a second. The buttons dont work correctly to turn it on, one of the volume buttons has become 'power' another button lets me select 'inputs menu' only briefly before shutting off and not allowing me to select another input because there is no select button working. The cable to the buttons and mainboard is put in correctly. I guess this has another firmware version on it. Also the psu makes a coil whine sound with the new main board connected. I hooked the old main board back up just to see if I can figure out if the processors are bad from cold solder. I turned it on, it flickered away, as it warmed up I pressed down on the heatsinks on main board. Nothing happened but when I tapped it the picture looked like it was trying to stabilize. I wiggled the ribbon cable a bit(CN1) and that seemed to be the culprit. So I cleaned both end of the cable real well and reseated it well and taped it so it couldnt travel out. It worked fine. I put everything back together and played some Skyrim for probably a 1 1/2 hr before it started that terrible flickering again. After I turned it off and walked away in disgust I came back after it cooled and was working fine again until it heats up. So now I am waiting for a new digital multimeter to come in mail and retiring the cheap analogue junker. I will test voltage regulators on main board to see whats going on. Does this scenario seem familiar to anyone? Was the cable connection a coincidence maybe? Anything I am missing here? Thanks for any advice.
  • selldoor
    replied
    MAIN BOARD MAIN BOARD
    Cant see any fuses as such but if you look near the bottom edge there are are two 0 rated resistors R301 and R303
    check them as if fuses. There are also a number ofvoltage regulators which may have blown. It will help if you can read this guide by retiredcaps
    https://www.badcaps.net/forum/showthread.php?p=261329
    I might be missing most of today but you have plenty to work on
  • selldoor
    replied
    OLD BOARD OLD BOARD
    Good morning - I should have said the offending cap will have possibly/ probably been damaged - check the two and see if either are completely
    shorted or open. - Resistance check on 200 ohms should do.
  • selldoor
    replied
    OLD BOARD OLD BOARD
    OK I think they may be on the otherside under the heatsink I perhaps see one with an M on it ( But that is actually on the new board pic.
    Its getting late here so if you want you can check all the things that look like
    fuses with an 0 on they are zero rated resistors used as jumpers but they may have blown like a fuse. Board marking are JXXX and measure 0.00 same as a fuse.
    You may as well test the fuses on the new board but post the result in a separate post. Another thing you can do is to find out on the bottom of the boards the solder joints for the BIG cap that is under the heatsink.
    You have to test that with power to the board and it is HIGH VOLTAGE! 400vDC I or someone will talk you through it.
  • rusty69
    replied
    Originally posted by selldoor
    OLD BOARD OLD BOARD
    Ok I assume that you have now cut the pins off the offending cap - which one was it Either mark a pic (back of the board)or tell the general area is it near a board number to identify it.
    Yes I did cut the leads already, unfortunately I don't remember which cap it was. I know it was either one of these two, that are marked by red boxes in the picture. I tested F100, F102, F104, F105 and they all tested 0.0 Ohms, I didn't see an F101 or F103.
  • selldoor
    replied
    OLD BOARD OLD BOARD
    Whilst the part numbers may be the same the boards are a little different.
    Set your meter on ohms 20 or autorange and touch the probes you should get 0.00 or close to.
    On the board back there are several fuses. on this board they are designated
    as F10X - I havent found F101 but there are a cluster in Pic 2 and they have
    either an alpha O or a 0 Zero on them.
    Put a probe to each end and record what you get on each fuse - should be the same as touching the probes.
    EDIT F100 is just to the right above the connector and has an S on it
  • rusty69
    replied
    Hopefully the power supply going out will have only affected the power supply. My suggestion would be to forget about it and think only on the new board but keeping in mind that damage may have hit the main board.
    Yes I would have thought the new board would at least light up but really need pictures of the boards as I requested. - You could always ask the seller if the power light should come on when the power is plugged in as you dont really want to be tinkering with it if it is going to be returned.
    An alternative would be to try and resurrect the old board- do a few tests on that.
    Thanks for bearing with me. Here are more pics of the mainboard, New power supply and Invertor Board.
    I definitely would like to test the old power supply as well, I just don't know where to place the multimeter probes on the board to test for output voltage.
  • selldoor
    replied
  • rusty69
    replied
    Didnt actually laugh out loud but the story did make me smile
    Not sure what we are doing here as you have posted pictures of the old board.
    What exactly are we troubleshooting- we can do the old board might be a lot of work
    might be simple, who knows.
    Or we can do the new board in which case we need pictures of the new board, the main board fronts and backs.
    Edit
    Was the new board "new" or "tested and working"
    LOL, sorry I guess my post was a little scattered, it was pretty late when I posted last night. The first thing I'd like to find out are what leads I need to test for output voltage on the new power supply. It should be fine, as It was purchased as "new" from a fairly mainstream online electronics parts supplier, but I would've expected the power led to at least light up on the front of the monitor. I guess right now I'd just like to verify that the mainboard and invertor are getting proper voltage.
    I also was hoping to hear what potential calamities might have occurred when the old power supply was powered up with the cap leads crossed.
  • selldoor
    replied
    Edit
  • rusty69
    replied
    Hi all, firstly I'd like to thank all those who contributed to this thread since it's inception. I was able to bring my L2410NM back to life a couple of years ago because of this thread, unfortunately like a couple others on here I just replaced the bad ones on the power supply the first time and not all the caps as I should have.
    This is gonna be long so please bare with me. For about the past 6 months I'd get intermittent blank screens while using the monitor, it didn't happen very often though so it never really bothered me too much. Unfortunately last week I went to turn the Monitor on and got nothing, the led light on the front was lit but the monitor wouldn't turn on. I assumed it was more bad caps in the power supply, and upon removal and inspection it looked like that was the case. All the old caps were bulging on the power supply, except for the Big one. So I ordered and replaced the caps. I put everything back together and tried to turn it back on, and got nothing, not even the led in the front. I took it back apart figuring maybe I accidentally reversed the polarity on one of the caps, Unfortunately It was worse than that.... the last cap I soldered I forgot to clip the leads and they were crossed and had also touched the chassis when I reassembled everything. So I assumed I'd fried the power supply and ordered a new one. I just installed the new power supply, and guess what? It's still not working, led isn't on in the front and it won't turn on. So I have a couple questions for you gurus.
    1) Do you think I fried something else i.e. (backlight invertor or main board) when I installed the power supply with the cap leads crossed?
    2) I noticed that the 4 caps on the invertor are all bulging, so I'm assuming I need to replace them as well, but wouldn't the front power Led light still come on regardless of the condition of the invertor? It was on when I first had the problem, even before I tried replacing the caps.
    3) Which leads do I need to test on the power supply to measure the output voltage? I have a digital multi-meter and have just enough electrical knowledge to get me in trouble. For the life of me I can't get any dc voltage readings out of the new or old power supply, but then again I'm pretty sure I'm not measuring the right wires.
    I really appreciate your help on this guys, I really would like to revive this Monitor. Thanks
    P.S. please don't laugh too hard at the lack of my soldering skills, I'm still learning.
  • Renesis13
    replied
    Originally posted by l2410nm
    What was your parts list?
    Mostly it was the same as the first list you posted (thanks!) but I used the info from the following posts to correct a few.
    One of them was a little fatter than the original, but still fit. All the others were identical. The tiny black one was 47uF but I could not read the voltage (the glue covered it).
    Parts list, copied from your list and tweaked:
    inverter board:
    P10294-ND (4)
    power board (under heatsink):
    P12357-ND instead of P14382-ND
    P14424-ND (2)
    P12417-ND (2)
    P14413-ND
    P12368-ND
    power board (two brown small ones):
    P14452-ND (2)
    power board (one tiny black one):
    P14411-ND/EEU- FR1E470 (1)
  • l2410nm
    replied
  • Renesis13
    replied
    Originally posted by retiredcaps
    If they just ordered what was obviously bloated, then they are ignoring the advice of the regulars which is to replace ALL the electrolytic capacitors. More details in my standard answer (regulars may skip).
    I was one of the first to fix a monitor by replacing capacitors earlier in this thread. I ignored the advice to replace all because I wasn't confident in my soldering skills. I instead replaced only the obviously bad one under the heat sink and two bad ones on the inverter board.
    However, about a year later the monitor went dead again.
    When I took it apart again, ALL caps under the heat sink were bulging, as well as the remaining two on the inverter board. This time, I orderded ALL caps on the power supply (except the big one), including the small ones not under the heat sink. I replaced them all and monitor is working again. Guess I learned my lesson.
  • l2410nm
    replied
    Put back together and working.
    Thanks again to everyone on this forum who contributed to this thread!
  • retiredcaps
    replied
    GWill order P12357-ND or P10230-ND Monday. retiredcaps, you have a preference between the two?
    Go with the Panasonic FM
    P12357-ND
    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 05:50 AM
    Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    09-07-2024, 05:00 AM
    Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
