NEC 2080UXi - looks dead but power led lit all the time
  • rman12
    • Jun 2010
    • 4
    I posted this originally on fixya but no response. Hopefully this forum can help.
    I have an NEC 2080UXi and the power led indicator is lit as soon as I plug in power and will not power off. Back light never comes on. Capacitors appear to be fine - no bulging or leaking. I did notice that a resistor did burn up and appears to be a small wattage from size of the leads. Does anyone know what resistance R915 is? It's located under the middle heat sink on the power supply board (the brown coloured board).
    I posted a picture (from another person on fixya) of what the insides look like except the capacitor on my power board appears fine.
    Any help is appreciated.
    Thanks.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: NEC 2080UXi - looks dead but power led lit all the time
    The pic is so far zoomed out, I can't make out any of the writing on the power board.
    Odd that it won't power off. Long shot, but try setting the monitor back to factory settings via front panel menus.
    If that doesn't work, test the on/off switch for continuity with DMM.
    --- begin sig file ---
    --- end sig file ---
    • Wrog
      • Oct 2009
      • 472
      Does the power LED color change when a signal is applied ("on" versus "sleep" modes)? Also, check for a blown fuse around the inverter power.
      • rman12
        • Jun 2010
        • 4
        As soon as the power cable is plugged in the power led is lit. It never goes to "sleep" mode. As I originally stated there is resistor that burned away - so there must be a problem somewhere.
        • rman12
          • Jun 2010
          • 4
          Here are some close up photos of the power board.
          • elinap
            • Oct 2010
            I have the same monitor, with the same problem. But, the resistor that you point at in my case is there,
            If you are interested, I can try to get a photo of it, so you can see its value from the colours.
            Do you know if it is possible to replace this power supply, or do you know of somebody that has got schematics and perhaps could repair it?
            It is such a pity to lose the nice monitor, because of 1-2 resistors that burned out...
            Best regards,
            Eli
            (in London, tel: mod edit- please do not post your personal info!)
            • retiredcaps
              • Apr 2010
              • 9271
              Post a pic.
              To read it, see
              http://wiki.xtronics.com/index.php/Resistor_Codes
              • jetadm123
                • 2169
                The resistor probably didn't burn up on it's own. The failure is usually caused by another component failing. Test other components surrounding the resistor for shorts.
                • fastslim
                  • Jul 2013
                  • Russia
                  Hi everyone! I have this broblem too. Power's led wouldn't change color, and monitor wouldn't show picter. It was two week ago. Last time i hear bang, and see smoke. Power plato burned near R917. How i can fix it?
                  • neodasan
                    • Aug 2013
                    I am having the exactly same problem with this. Anyone knows a solution for this?
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • Andreas_de
                      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                      by Andreas_de
                      Hello!
                      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                      04-12-2025, 10:38 AM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
                      HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 02:15 PM
