Viewsonic VX910
  • OSE
    • May 2010
    • 6
    Viewsonic VX910
    I am having a power problem with my VX910. The green light on the power button will light up however the screen remains blank. After a few seconds the screen will give an image for maybe 1 second. Once that image appears it quickly vanishes and the monitor power cycle through this process repeatedly.
    From what I've been reading online these monitors seem to have quite a few issues with bad caps and other power issues however I don't know which parts should be replaced.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic VX910
    All the bad ones.
    Open up the case, post pictures of the power supply board - top and bottom. (Note the link to the proper procedure for posting pictures in my signature.)
    PlainBill
    • OSE
      • May 2010
      • 6
      Re: Viewsonic VX910
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Re: Viewsonic VX910
        I'd like to beleive that all problems come from the power board however this is not true. There is a digital processing board that is in this monitor also. Whenever possible, post a pic of it (front/back) also.
        What type and values are the caps on the power board?
        • PlainBill
          • Feb 2009
          • 7034
          Re: Viewsonic VX910
          Not an exact match for the symptoms I am seeing, but check the transistors I have circled to see if they are shorted.
          PlainBill
          • OSE
            • May 2010
            • 6
            Re: Viewsonic VX910
            • OSE
              • May 2010
              • 6
              Re: Viewsonic VX910
              PlainBill
              Is it ok to test the transistors while still on the board? I had done some initial testing after getting your reply and the readings I was getting were rather odd. It seemed like however I placed the leads on my meter I always got a reading from it.
              • PlainBill
                • Feb 2009
                • 7034
                Re: Viewsonic VX910
                OK, a newbie. We can handle that.
                Yes, you can test the transistors without removing them. Here is the procedure I use:
                Set the DMM to the lowest ohms ohms range - typically 200 ohms.
                There are three pins on these transistors (in the picture above, the pin at the left connects to the middle pin on the right). Numbering the pins on the right 1 - 3, measure the resistance 1 to 2, 1 to 3, and 2 to 3.
                PlainBill
                • OSE
                  • May 2010
                  • 6
                  Re: Viewsonic VX910
                  I numbered the pins from the bottom to the top like I have below.
                  -3
                  -2
                  -1
                  For the transistor on the far left of the picture I got the following readings
                  1-2, 16.8
                  1-3, 8.9
                  2-3, 25.2
                  The next transistor ( second from the left) gave me these readings
                  1-2, 25.4
                  1-3, 9.1
                  2-3, 16.9
                  The two transistors on the right side of the picture do not produce a reading when connected from pins 1-2 and 1-3. They do however produce a reading of 168 Ohms when connected at pins 2-3.
                  I have attached a picture of my meter in case I may have a setting incorrect. Better to get something like that sorted out now rather than later.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: Viewsonic VX910
                    -3
                    -2
                    -1
                    1-2, 16.8
                    1-3, 8.9
                    2-3, 25.2
                    1-2, 25.4
                    1-3, 9.1
                    2-3, 16.9
                    Good idea posting the picture. You did the measurements properly. That 9 ohms sounds a little high, but the comparison to the other side indicates there is a problem.
                    If these transistors are the ones I expect, they should have the letters DK on one end, and Qx on the other (x can be any letter; on mine it was H). The actual part number is Rohm 2SC4672 and they are available from both Digikey and Mouser for about $.75 each.
                    Check the transformers, capacitors, etc. The service manual for a Belinea 101910 fits this monitor.
                    PlainBill
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2640
                      Re: Viewsonic VX910
                      PlainBill
                      now that you say it, i remember where i've seen those insides.. in my own Belinea 101910
                      caps are the primary suspect.
                      if you have an external 12V power supply with at least 1.5A, you could try to hook it up to the powersupplie's output pins while it's connected up.
                      sort of like this (notice the 2 wires going into the connector between the PSU and controller board)
                      that way the monitor should turn on.. easiest way to test if the inverter part of the powersupply and LCD controller board are OK.
                      i think the pins were labeled. if not, follow the traces from the pins to the cap right next to that pin header (on the power supply board!) which connects both boards. that's your "12V injection point"..
                      • OSE
                        • May 2010
                        • 6
                        Re: Viewsonic VX910
                        Thanks for the help, ordered the transistors and hopefully will be able to report a successful repair.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2640
                          Re: Viewsonic VX910
                          as for the caps on the powersupply/inverter combo board, 16V caps will do just fine, as there's only 12V coming from the PSU..
                          they usually have 25V 470uF CapXons (crapxons) in there for some reason..
                          they get cooked to death in those monitors as they're pretty hot-running..
                          my own one is polymerized (16V 470uF nippon chemicon), allthough thats pretty much overkill..
                          good luck
                          • ajsemtb
                            • Jul 2010
                            • 79
                            Re: Viewsonic VX910
                            Can I chime in on this thread? I have this same monitor, same issue, and my power supply board looks the same as well, with the same "burned" inverter on the right. If you look back at the very first picture he posted, the "white Box" on the right side has dark discoloration around it, and then the back picture on the left (where the white box now is) has a "circle" area of what appears to be a burned area. Mine looks just like that, and also on this forum somewhere I read that to test the ohms at the diodes on either side and you should get 750 ohms on boths sides, and if not, then one is probably failed. I did that test and I got 745ohms on one side, and 9 ohms on the other. The burned one, obviously game me the 9 ohm load. SO, none of my caps looked bulged at all, which I was disappointed to see, (hoping for an obvious quick fix) so, do the transisters sound like they would be the problem?
                            And OSE, did your repair work?
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Re: Viewsonic VX910
                              For a diode test, turn your multimeter to the diode setting.
                              Put black probe on side and red on the other. Record the measurement. Then reverse the probes and record the measurement.
                              One should read around 0.5 to 0.7 and the other should be 0L.
                              --- begin sig file ---
                              --- end sig file ---
                              • ajsemtb
                                • Jul 2010
                                • 79
                                Re: Viewsonic VX910
                                Originally posted by ppm007
                                Also check die Schottky Diode near those 2SC4672: D9 and D10
                                At a german board a guy with same problem wrote:
                                You can check both Inverters by R18,R22 and R20,23: if ok everyone should have 750 Ohm. If one Inverter is broken, the resistance should be lower
                                Technically, I wasn't doing a diode test. I was following this test that was on another thread in this forum. The thread was simply Viewsonic VX910 that was also discussing this problem. I haven't done the test on the transistors that was mentioned in this thread yet, as I went through a major cleaning upheaval in my office/shop/studio and my project was halfway reassembled to keep it together. I will hopefully get it back out this evening and test the points on the transistors and post the readings as well as pics later.
                                As for my experience, I'm a tinkerer, I have moderate soldering skills, but I am concerned about soldering those tiny little transisters... Any tips on soldering points that small? I have a 30 watt soldering iron and a 45 watt de-soldering iron, that I usually use to solder points on boards, because it makes pretty little points.. LOL and I can "cup" the molten solder in the nose instead of trying to feed wire solder into my iron tip.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Re: Viewsonic VX910
                                  I like the soldering videos by Curious Inventer on youtube.com. These are the 2 I suggest a lot to people, but he has much more on his channel.
                                  http://www.youtube.com/watch?v=3NN7UGWYmBY
                                  http://www.youtube.com/watch?v=I_NU2ruzyc4
                                  • ajsemtb
                                    • Jul 2010
                                    • 79
                                    Re: Viewsonic VX910
                                    WOw, those vids were great! Thank you for that. I got a lot of tips from those. Also, that's probably why my tips die so quickly, I don't tin them after I'm done, just clean them and boy do they get corroded!
                                    Back to my chip: OK well, I'm not going to add pics, because it looks exactly like the chip above in this thread, however, I did my own test for the transistors and heres what I got, again top to bottom 3-2-1.
                                    both on the right side were (closely enough to each other)
                                    1-2 745 ohms
                                    1-3 5.37k
                                    2-3 4.51k
                                    and the chips on the left
                                    1-2 9.8
                                    1-3 9.4
                                    2-3 .6 ohms
                                    SO, I would say those ones are definitely fried...
                                    Also, my caps are XICON. Haven't seen that name yet in these threads. Anyone? They do not seem to be bulged at all. :/ there are 2 470uf 35v and 2 330uf 35v. Oh, and a big one 1000uf 400v and a little one 10uf50v. Both those are CapXon.
                                    Are there any other components I should/can check that regularly fail with these power supplies? What's the final recommendation for chip repair? Thanks in advance for your help. If the monitor works again, great! If not, that sucks, but oh well. Already bought a replacement, but I don't throw anything away that I "might" be able to fix.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: Viewsonic VX910
                                      Yes, tin them after you are done. Tips are not cheap on quality irons.
                                      1-2 9.8
                                      1-3 9.4
                                      2-3 .6 ohms
                                      That is definitely shorted.
                                      Also, my caps are XICON. Haven't seen that name yet in these threads. Both those are CapXon.
                                      I think any 19 inch LCD monitor is worth saving.
                                      Members here hate Capxon and recommend replacing all the Capxon.
                                      Caps do NOT have to bulge in order to be bad. They can out of uF tolerance and have ESR.
                                      You can also test our transistors and voltage regulators for shorts (with power OFF and monitor unplugged). Test to ensure all fuses are good. They should measure 0.3 ohms.
                                      I had zero soldering skills when I started, but I managed to install new transistors. The key to removing the old ones is to ADD a bit of fresh 60/40 solder. Then I use a solder sucker to remove all the solder. This is usually good enough so I can remove the old transistor.
                                      • ajsemtb
                                        • Jul 2010
                                        • 79
                                        Re: Viewsonic VX910
                                        Ok, now you can officially laugh at me... What are the fuses on this board? If they don't plug in somewhere, I wouldn't know they were fuses! LOL And to clarify, the transistors are are mounted to the heat sink? (other than the tiny ones on the bottom?)
                                        Also, looking at this board a little closer, I'm thinking these caps have already been replaced once. Well, the Xicon ones anyway. The reason why, is a couple aren't sitting flush and the solder jobs on the back are good, but not great, and appear to have some heat coloring around the points that are similar to not careful soldering, but I suppose could be from the Caps... Do caps get hot? ANywho, I've seen on these posts where to buy these parts, so I will order the tiny little transistors, and the caps and hopefully have a working lcd again.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                          HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
