Opening the LG 25UM58-P Monitor
  • manuforti1314
    • Sep 2021
    • 44
    • United Kingdom
    As per the title, does anyone know how to open the case on this LG widescreen monitor?
    It looks like the case splits front to back but I cannot for the life of me get it apart. Starting to think the panel might actually come out from the front once the bezel is removed.
    Any help appreciated.
    Thanks.
  • manuforti1314
    • Sep 2021
    • 44
    • United Kingdom
    Re: Opening the LG 25UM58-P Monitor
    I have worked out how to do this. The panel comes out the front of the case.
    2 screws on the underside of the main case allows the lower LG bezel to be pried off. Once this is off I removed the stand and lay the unit on the back.
    Then comes the scary part. The panel has a plastic parts on the sides that wrap to the back. The clips are on the back not the sides. I took 2 thin metal spudgers and on the top right corner of the screen put one in between the case and panel on the horizontal and the other on the vertical, as close to the corner as I could and as far in as i could, until they were touching the back of the case.
    Then lever the panel up. It makes some horrendous snapping sounds as the clips release. Then work the way round the edge doing the same levering action.
    This video helped my understand how the monitor is put together.
    https://youtu.be/GZp8Abzbl8o
    I needed to add some insulating tape to the board to insulate things and the monitor works like new.
    • Russ17
      • Mar 2018
      • 125
      I too had difficulty in getting the case to disengage from the clips.
      My suggestion is to remove the stand, then the two screws which hold the lower front bezel in place. To remove the bezel, start on one end, and pull out about 15mm, then slide a plastic ruler between the screen and the bezel, about 100mm in from the screw and push down (opposite direction to the top of the screen) to release the first tab, then do the same about 60mm from the IR receiver/ on-off button unit in the middle, and push down. This should release the two tabs on the one side, now repeat from the other side. The bezel should now be free.
      To release the screen from the back panel, place the screen face down, on something soft over a firm surface.
      Lift the bottom edge (stand edge) of the casing about 50mm and then push the stand bracket inwards, which, with enough force, should release the clips from the back panel, allowing the screen to be removed from the front. It does take bit of force.
      This method avoids the risk of damaging the edge of the screen using pry tools.
      • wattage
        AOC AG493UCX 49-inch monitor - Firmware request
        by wattage
        Hello Badcaps Community,
        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
        07-13-2025, 04:41 PM
        ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
        This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-06-2024, 10:50 PM
        ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
        This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-06-2024, 11:05 AM
        ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
        This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
        ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
        This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
