Daytek F19AH
Re: Daytek F19AH
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Daytek F19AH
I got one of those SMD hot air blowers so removing it will be no problem. The problem I am having is I have already been looking for a replacement and this part is proving difficult. 0 results at digikey, findchips gives me a 14 pin IC ect.
Could you possibly tell me a little more about the "drive signal path"?Comment
Re: Daytek F19AH
As far as the signal path, that has started looking better. By the part numbers you gave me IC1 is the inverter controller. The datasheet is here. I've marked up the drive signals; they look refreshingly similar to the datasheet. Initially I thought the path was much more convoluted. One possible explanation for the initial failure was both transistors turning on at the same time.
Re: Daytek F19AH
I came up with the ON semiconductor NTD6416ANT rated at 100V 17A, 81mohm. However, the rise ansd fall times are a possible issue.
Another possible solution is to dial up digikey's 1-800 number and tell them you wanted to order the Fairchild NDB4060, but that it's out of stock and if they can recommend a substitute. Other members have tried this idea with success.
Also, on the top of the board, above the inverter transformer and to the right of ceramic cap C36, are two 22 ohm 1W resistors. These seem to be sitting above or near the inverter transistors and look to be subjected to a large amount of heat. Measure their values and check to see if they're connected to the inverter transistors. Although ceramic caps rarely fail, I'm starting to wonder about C36 and C37?Last edited by jetadm123; 10-12-2010, 09:21 AM.Comment
Re: Daytek F19AH
After a bit of digging around I looked at the Post #1 in this thread. How I thought these to PS boards were alike it seems there is indeed a difference. The drive transistors in that pic that I can make out are:
D444
US?822
4060AL -
D444 -
Does it seem like a D444 could be suitable replacement?? If so I have readily found some on ebay and the auction says "This MOSFET transistor can be found in Xerox, Mag Innovision, and Proview LCD monitor."
http://cgi.ebay.ph/LOT-4-AOD444-N-Ch...-/200357432833Comment
Re: Daytek F19AH
D444
US?822
Very good observation on your part! It reinforces the reason why photos are needed, even if you've got the "same board" as the previous person.
Here's the deal: It's not unusual for the manufacturer to come up with different versions of the same board. The model number of the board could be the same, but they could have a different revision or "rev" letter. Also, a later revison like "rev B" or "rev C" usually indicates an improvement to the previous rev. So, the question is was your board produced before or after the board in post #1? If after, maybe the 4060AL mosfet was used as an improvement over the AOD444. Or is it vice versa? Or did these guys just run out of the AOD444 and substitute the 4060AL?
As for the AOD444 being used in Mag, Proview, etc. It's probably true, but those power boards were made by Mirage Electronics. Yours is made by Li-Shin.
Although the AOD444 is 12A vs 15A for the 4060AL, it may still be ok. It's usually the rise/fall times that throw people for a loop.Comment
Re: Daytek F19AH
D444
US?822
4060AL -
D444 -
Re: Daytek F19AH
Something else I just noticed. IDK if this means anything the datasheet for the for the 4060AL is dated March 1998 while the one for the D444 is dated June 2004 so I would guess that the D444 is the improvement over the 4060AL???Comment
Re: Daytek F19AH
Re: Daytek F19AH
Hmm OK. Umm does the D444 look suitable. I'm at a loss with all those terms on the data sheets ie: "drain source on state resistance"...Not a clue lol. I have never gone this deep into circuitry. I was just trying to match the numbers on the sheets and is seem the D444 has a few values that are a little higher.Comment
Re: Daytek F19AH
Re: Daytek F19AH
OK I am gonna go ahead with these D444's. I had another look at the board and the only real difference between mine and the original post other than the transistors I can see is the stickers/markings that were added to the board afterwards:
-Number stamp on filter cap (Original post 5718D - Mine 5914D)
-Number stamp on transformer (Original post L0525 - Mine L0528)
-Barcode sticker underneath the board (Original A30534134542 - Mine A30544023768)
-Sticker by inverter (Original R0194L7200 - Mine 83A000013)
-Sticker between coils
The Li Shin #'s right by the 110v in on top of the board are an *exact* character for character match.
Although the stickers previously mentioned seem to be of a little higher number on mine than in the original post which pretty much confirms my thought the F19-DH was a remake of the F19-AH so the 4060AL's were probably the newer one compared to the D444.
I'll take the readings of those resistors and ceramic caps today and pull that inverter and post some pics of it.
For caps: If the meter goes to infinite its shorted but if it rises one way (charging?) and drops the needle back (discharging?) then it is good. Am I correct on that statement?Comment
Re: Daytek F19AH
Re: Daytek F19AH
OK I could not get anything to happen with the caps on resistance mode on both the digital and analog meter but when I put the digital to capacitor checker the one on J14 side read .34nF and the one on J15 side read .37nF.
The numbers on the caps are:
471k
1Kv
The resistor on J14 side is 33.8ohm and by J15 is 33.4ohm
Pulling the inverter transformer not surprising the dark scorch mark is on the same side as the shorted transistor.Comment
Re: Daytek F19AH
471k
1Kv
The resistors are OK, if the color bands are orange, orange, black.Comment
Re: Daytek F19AH
Actually the resistors and caps were all pulled for testing.Comment
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by mferna14Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate.
by mferna14Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
- Loading...
