Daytek F19AH
  • UserName666
    replied
    Re: Daytek F19AH
    All the caps are fine. This started after reinstalling D108.
  • alexanna
    replied
    Re: Daytek F19AH
    Visually inspect all your solder joints on the capacitors you replaced, And then wiggle the caps to check for movement on the solder pads. There is a possibility you moved something breaking the circuit.All this should be done power off.
    Al.
  • UserName666
    replied
    Re: Daytek F19AH
    OK that could be of some use if I do decide to try it but for now is there anything to check that might explain why all my readings went strange after putting D108 back in? I can trace 115 up to the rectifier which is putting out 161 to the filter cap but lose it from there. Something caused everything to go off after putting D108 back in.
  • retiredcaps
    replied
    Re: Daytek F19AH
    Originally posted by UserName666
    Heat damage to D108 while soldering it in??
    If I fried IC101 I'm gonna have to stop because thats way too small to solder.
    I would say no to the heat damage. D108 is attached to a heat sink. When you soldered it back in, the heat sink sucks up some of the heat so D108 should have NOT gotten hot.
    For soldering something that small, check out this video by CuriousInventor. After watching it, I think you should try it on some junk parts and attempt on the real thing.
    http://www.youtube.com/watch?v=3NN7UGWYmBY
    If you still are not confident, ask around who has good soldering skills and offer a 6 pack in exchange for their soldering services?
  • UserName666
    replied
    Re: Daytek F19AH
    That would indicate a problem with the SG6841 or you managed to create a solder short. Probably the former.
    PlainBill
    Possibly by forgetting to solder in D108 before plugging it in??
    Soldering iron never went near IC101. All solder joints clear.
  • UserName666
    replied
    Re: Daytek F19AH
    Originally posted by jetadm123
    Any chance the power supply has started? Remember, the clicking indicated the power supply was trying to start. Checked for 12V at the output? Power LED on? Have the voltages at pins 2,7 and 8 on IC101 changed?
    Yes they have:
    Pin 1 - 2 = .000 ~ 001v
    -it was-
    Originally Posted by UserName666 View Post
    -The voltage on U1, pin 2.
    ***This one is giving really jumpy readings between .035v and 1.4v
    Neg - Pin 1
    Pos - Pin 2
    Pin 1 -7 = 1.582v
    Cant find a previous test for 1-7
    Pin 1 - 8 = 1.573v steady
    -it was-
    -U1, pin 8. Do you see pulses there at about the same rate you saw them across the 10uF cap?
    ***Sort of. Fluctuates between .3?? - 0 - .4?? then it will fall to 0 for a few seconds then do that over again on a constant cycle.
    Pos - pin 8
    Neg - pin 1
    Ahh, crud. Here it is.
    PlainBill
    All caps as you marked
  • retiredcaps
    replied
    Re: Daytek F19AH
    findchips.com finds no SG6841 anywhere. They are available on ebay for about $6 total (part + s/h).
    For those that haven't used findchips.com (I just discovered it), it searches all the popular sites like digikey, mouser, and displays stock and price.
  • PlainBill
    replied
    Re: Daytek F19AH
    To narrow things down a little more I tested a few more things.
    -The 10uf 63v cap by the filter cap that was previously fluctuating between 11 and 17 volts is now sitting steady at 1.584 volts
    -IC101 Between pins 1-3 the input voltage is 4.27 volts where it used to fluctuate from 15-19v
    -No voltage coming to opto isolator anymore
    I will say that when I put D108 back in it did take quite a while. If it was good out of board and I somehow heat damaged that part does that give cause for the previous symptoms? If now damage it would have been the same result as not soldering it in???
    PlainBill
  • PlainBill
    replied
    Re: Daytek F19AH
    "I've marked what should be the + and - sides of the caps; please verify they are correct." - Did you upload a pic because its not showing on this end.
    By 9v that just means a everyday 9v battery??
    Could someone possibly address my concern in post 72 about having forgotten to solder D108?
    PlainBill
  • UserName666
    replied
    Re: Daytek F19AH
    No because when I noticed it first stopped clicking I hooked everything backup thinking it was fixed but didnt work.
    There is 161 going into the transformer but nothing coming out. I'll have to find my previous post about pins 2,7,8 to find out what it was before.
  • UserName666
    replied
    Re: Daytek F19AH
    The resistance between pins 1 & 3 is back to 00.3ohms. Is there any reason the transformer may have stopped clicking? At a TOTAL loss now.
  • jetadm123
    replied
    Re: Daytek F19AH
  • UserName666
    replied
    Re: Daytek F19AH
  • retiredcaps
    replied
    Re: Daytek F19AH
    There is a good chance there is no more damage. With D108 out of circuit, the voltage stops right there. The circuit is "open".
  • UserName666
    replied
    Re: Daytek F19AH
  • PlainBill
    replied
    Re: Daytek F19AH
    There was no smoke just a faint burn smell at the time it went out/died.
    I've got a few ideas running around my mind. I see two possible approaches. The first will require a fairly good soldering iron. The second will require a variable power supply, or you may be able to get by with several batteries.
    The first thing to double (triple) check is the orientation of the caps you installed. I've marked what should be the + and - sides of the caps; please verify they are correct.
    The second thing to try is I have marked two inductors in the upper left hand corner with a white L. If you have received your soldering iron, remove the lower one on the board and see if the power supply will work. This disables the inverter. (I'm not sure your 'cold soldering tool' will work on anything this heavy. That is heavy gauge copper wire).
    Another approach will require a variable DC supply or several batteries. (Don't remove the inductor for this test). 'D' Flashlight batteries, a 6 volt lantern battery would be ideal. Even a 9V DC transistor radio battery might be sufficient. Assuming you are using a 6V battery, hook the - terminal of the battery to the - lead of any of the caps you replaced. Next, measure the voltage of the battery. It will probably be above the nominal output voltage for the battery. Hook the + terminal to one of the + leads of any of the caps you replaced. Now measure the voltage of the battery again, then disconnect the battery. No need to run the battery down. What voltage did you read with the battery hooked up?
    PlainBill
  • UserName666
    replied
    Re: Daytek F19AH
    So I put D108 back in, plugged it in and the transformer is not clicking anymore. Hooked everything up thinking it might be fixed. Did not work...Started taking it back apart again and realized after I put on the screw & nut that I forgot to solder it. Soldered it and plugged it in again. The transformer still is not clicking. I think Im now further behind then when I started. Is it time to give up yet? Would forgetting to solder that in have blown something else????????????
  • alexanna
    replied
    Re: Daytek F19AH
    My idea of poke and prod was to move and flex things ,see if some thing will change.
    If i understand things correctly isnt the opto pin 1 and 2 one the hot side and 3 and 4 on the cold side could chosing the wrong ground have made a difference in the readings?
    Al.
  • PlainBill
    replied
    Re: Daytek F19AH
    Originally posted by alexanna
    Try the poke and prod approach on the opto,Or just reflow the solder?
    Al.
    I don't see the point of that. The design of the SG6841 is that the opto-isolator pulls the feedback input down to regulate the output voltage. A bad solder joint or open opto-isolator would allow the output voltage to rise. UserName666 has observed voltage pulses on both the input and output of the opto-isolator
    Still, you bring up a valid point. Most of the parts check out. We're down to the point where only a few parts remain untested. The TL431 shunt regulator, the opto-isolator, the SMPS controller, and the power FET.
    But by nature I abhor 'shotgunning' instead of logical troubleshooting.
    PlainBill
  • alexanna
    replied
    Re: Daytek F19AH
    At this point PlainBill is trying to find a rational explanation for the behavior of the output. Why is voltage detected at the input side of the opto-isolator, but not at the output? And what is the expected output voltage? Where did teh 'magic smoke' come from (or is that another monitor)?
    PlainBill
    Al.
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • korben_dallas
    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
    by korben_dallas
    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
    MY QUESTION:
    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
    02-14-2024, 12:23 AM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • mferna14
    Logic Board 820-00840-A Missing EDP_BKLT_EN
    by mferna14
    Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
    07-10-2024, 05:18 PM
  • mferna14
    Logic Board 820-01987-A missing PP3V3_S5
    by mferna14
    Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
    06-07-2025, 05:07 PM
