LG 1510S Monitor Issue
  • FercHeliX
    • Sep 2021
    • Iran
    Hi
    There's this old LG 1510S LCD Monitor that had 2 issues, one with inverter board and one with image display (mainboard maybe), the issue with the inverter was that when i turned it on it goes off after 1 or 2 secs. and the problem was with the tuner caps on inverter board, after i changed the caps monitor stays on but there's another problem that if I turn it on by the power button, no signal message does not show on the screen, but if I let it stay on and disconnect by the power cable and connect it again the no signal message will appear, and one more thing...the 12V power is 17V before i turn on the monitor but after turning it on it will drop to 12 volts, and about 5 volts to main ... I have 5 and 4.3 and 3.3 and 2.5, the 4.3 is on one leg of regulators on mainboar instead of 5 volts... souldn't it supposed to be 5 volts on the v in of regulators and 3.3 and 2.5 on Vout ?!
    please help ... thanx alot.
  • DqMagetz
    Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
    by DqMagetz
    Good day!
    I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
    Here are the voltage readings:
    • Input – 19V (stable)
    • +LCDVDD – 3.3V briefly, then drops to 0V
    • EDP_HPD – 3.3V briefly, then drops to 0V
    • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
    • EC BKOFF# – 1.8V briefly, then drops to 0V
    • PANEL_OD_EN – 0.3V
    Is it possible that the EC chip is corrupted or damag...
    07-12-2025, 09:37 PM
    by momaka
    03-15-2023, 10:17 PM
  • Rick_1234
    LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
    by Rick_1234
    Good evening, gentlemen.
    I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
    To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
    https://drive.google.com/file/d/1L6S...ew?usp=sharing
    Things I tried
    - Bought a new AC adapter thinking that was the problem but the problem...
    06-22-2024, 04:44 PM
  • u666sa
    HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
    by u666sa
    Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
    Platform: ipa32 la-m024p rev 1b
    Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
    I found a short on the other side:
    10-04-2025, 05:03 PM
    Wise Wing F199 19'' LCD monitor - recapped
    by momaka
    Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
    I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
    When I saw the Craigslist post, I wasn't...
    08-24-2020, 10:58 AM
