Samsung 930b monitor (need help with problem)
  • madhockeyplaya23
    • May 2010
    • 5
    The monitor won't show up anything, the vga cable and power cable are connected and when I turn it on it doesnt do anything, the backlight wont even turn on but the power button light will light up.....
    anyone knows what the problem may be? and if you do is it easily fixable by opening up the monitor and fixing it by yrself?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung 930b monitor (need help with problem)
    Define 'easily'. It sounds like a problem with the inverter; possibly a blown fuse or shorted transistor. I'm sure I could fix it (or at least identify the problem - some components might not be readily available).
    Whether or not YOU can fix it is another matter. Do you have a DMM? Soldering iron? Camera? Know how to follow directions on using them?
    PlainBill
    • madhockeyplaya23
      • May 2010
      • 5
      PlainBill
      thanks!!
      I looked at the lcd board and it looks like three green capacitors are swollen. but im not sure if that would cause the problem.
      I do hav a soldering iron because I fix other electronics like psp's 360's ipods phones and just resoldering wires. But I have never fixed a monitor before.
      here are the pictures:
      • PlainBill
        • Feb 2009
        • 7034
        thanks!!
        Information on posting pictures.
        Replace all the caps with low ESR name brand caps. Check the FAQ for acceptable ones and sources.
        PlainBill
        • madhockeyplaya23
          • May 2010
          • 5
          PlainBill
          Noob question >< still learning.
          Is it okay to have a more Microfarad capcitor then the orginal one that was bad but have the same amount of Voltage?
          Thanks!
          • pedro
            • 199
            • AUSTRALIA
            Is it okay to have a more Microfarad capacitor then the orginal one that was bad but have the same amount of Voltage?
            Thanks!
            Yes, but don't go overboard. If the original is an odd (read "less likely to be found as a stock line") like 820uF then go for 1000uF. But normally there is no need, and sometimes it will catch you out as the size will increase and it won't fit in the original space.
            The main things are:
            • 105C, low ESR, quality brand/series
            • no lesser voltage rating
            • no lesser capacitance
            • check dimensions
            Friends don't let friends buy Samsung ....
            • madhockeyplaya23
              • May 2010
              • 5
              • check dimensions
              thanks I just ordered three caps.
              How do I know where the fuse is located on the board?
              • mcfischer
                • Dec 2008
                • 12
                The fuse is the brown plastic cylinder next to the AC jack.
                Mike
                • madhockeyplaya23
                  • May 2010
                  • 5
                  Mike
                  Thanks for all the help!
                  • CptChronic
                    Samsung LU32J590UQUXEN Monitor display problem
                    by CptChronic
                    I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                    Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                    But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                    04-24-2023, 04:33 PM
                    09-07-2024, 05:50 AM
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
                  • alro7779
                    Samsung UN55MU6103F video problem; has colored stripes on the display
                    by alro7779
                    Hello, everyone!
                    A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                    09-27-2025, 11:29 PM
                    09-06-2024, 11:40 PM
