Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
I'd just like to say thank you for providing all the information in this thread.
I had the acer logo problem and bought the bits from Mouser.
Changed all the caps 1st then got a different problem.
Replaced the mosfets and the fuses with 1.5a and everything is running perfect again.
Thanks again.
help plz. I have this acer al2416w the problem is turn on but only yellow amber on. I tested the psu missing 24v and 12v. Only voltage show is 5v. The caps seem okie no blown up.Leave a comment:
Rubycon ZLH is a very good choice. They will be physically larger than the original caps, but if you're careful, you should be able to get them to fit.And Rubycon ZLH should be a good replacement?
Found these in a local store https://www.elfa.se/elfa3~lv_lv/elfa...2-69&toc=19089
Also, check the 3 fuses on the board to verify they are good.Last edited by jetadm123; 11-27-2011, 02:01 PM.Leave a comment:
Found these in a local store https://www.elfa.se/elfa3~lv_lv/elfa...2-69&toc=19089Leave a comment:
I think that would be a very good place to startLeave a comment:
I read all the thread and tried to understand it all, but it was very confusing.
So
I got my hands on an broken Acer al2416w,
Symptoms are:
When I turn it on the acer logo shows for a second, then everything is black,
but if I use a flashlight I can see that the monitor is showing the picture, just the backlight isn't working.
I opened it and all the capacitors and mosfets seemed fine, no burnt smell or anything.
What should be my first step?
If I understand correctly, it should be an inverter or ccfl problem,
should I replace the 10 35v 100uf capacitors on the inverter board?Leave a comment:
I don't know the EHR series, but I'm sure it appears on the Hitano website.Cant seem to find them on the badcaps link.
What about these Hitano brand??
http://www.ebay.co.uk/itm/20-Electro...item1c17b0e1fb
I have used , and continue to use, Hitano EXR 105C low-ESR caps in monitor repairs. Haven't had an issue or come-back yet. I suggest going to their website and comparing series.Leave a comment:
http://www.ebay.co.uk/itm/20-Electro...item1c17b0e1fbLast edited by folinsbee; 08-14-2011, 01:50 PM.Leave a comment:
Yes, those caps are leaking. As a matter of fact, there are 10 of those caps on the inverter board and they should all be replaced. The input to the inverter is an unregulated 24V, therefore, a 25V cap won't suffice. The original caps are rated at 35V. Recommended brand/series replacement caps are below:
https://www.badcaps.net/forum/showthread.php?t=2280Leave a comment:
Maybe. There are two substances that could be called a 'rusty substance'. One is normal, one isn't.Hj folks
I have the common problem with a acer monitor i was given. Acer logo for 2 secs.The screen was replaced and worked for 1 day so i opened it up and looked at the inverter caps.
There was a rusty substance on four of them .Could this be the problem ??
BTW i.m a novice on these things.
It REALLY helps if you provide a picture using 'Manage Attachments' - below the test entry area.
PlainBillLeave a comment:
Hj folks
BTW i.m a novice on these things.Last edited by folinsbee; 08-13-2011, 09:43 PM.Leave a comment:
Good job of troubleshooting.This thread is awesome! My situation is exactly the same as someone else described: found the monitor on the street, it turns on with the Acer logo and goes blank.
I was first suspecting the power supply because the 24 V rail turns off after about 4 seconds, even when neither the inverter nor the LCD controller board is plugged in. Is this also the case in your power supplies?
But then when I desoldered one leg off of each of the infamous 10 cap on the inverter board, it turns out that 5 of them show less than 1uF, 2 of them show about 20uF and only 3 show something close to the default 100uF. Bingo.
So, of course I have an issue with the inverter, but can someone confirm that in your operational/repaired unit the power supply also shuts down the 24v rail after about 4 seconds without the inverter & control board connected?
Designs can vary, but usually the power supply consists of a standby supply which is always on, and a main supply which is controlled by the signal board. It would not be unusual for it to shut down without the 'on' signal present.
So, of course I have an issue with the inverter, but can someone confirm that in your operational/repaired unit the power supply also shuts down the 24v rail after about 4 seconds without the inverter & control board connected?Leave a comment:
made it worse what ever that is i think i now need to replace it no more buzzing no more picture looks like inverter does not power up anymore due to me messing with that parthttp://i185.photobucket.com/albums/x...n/inverter.jpg
re soldered all my caps and mosfets and the buzz seemed to move
linked a pick the what i now think is buzzing(what is it)Leave a comment:
If you get it working, please post a photo.Leave a comment:
got the screen on again and the nasty buzz apears to be coming from the p2804 next to the p5504 that blew up (replaced all so the new one is noisy) old one i presume was also noisy as the buzz was present before)
this is what i purchased
http://www.chsinteractive.co.uk/elec...nce-8x11mm.htm
will try and resolder my caps a bit better
Cheers SingionLeave a comment:
"2 seconds to black" is documented in posts #13 and #14 at
https://www.badcaps.net/forum/showthread.php?t=10419
Concentrate on
1) bad caps especially if you did not replace all the electrolytic caps or used the wrong ones
2) poor soldering
3) bad inverter transformer
4) bad ccfl and/or wiringLeave a comment:
			by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
			by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
 But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
 I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
			by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
			by keepreadHi there!
Someone gave me their old monitor, it's Dell S2715ht.
The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs... -
			by momakaHere's another LCD monitor repair: Westinghouse L2210NW.
Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
Pictures of the monitor outside/case after a brief...-
 - Loading...
