Missing resistor? Viewsonic VP930B
+ More Options
Posts
  • sghill99
    • Mar 2010
    • 52
    I have a couple of Viewsonic VP930B monitors. I noticed that the power supply for the one that works has a 4.7K resistor. The power supplies that failed prematurely did not have this resistor.
    Do you think the premature failure of the power supplies has anything to do with this missing resistor?
    The VP930B power supplies all look the same with the exception of this missing resistor!
    Thanks much!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Missing resistor? Viewsonic VP930B
    Thanks much!
    What was the nature of the failure?
    PlainBill
    • sghill99
      • Mar 2010
      • 52
      I didn't dig into what the failure(s) were, the monitors just wouldn't fire up. Each of the bad power supplies had some bad caps which I replaced. I went out to Fry's yesterday and picked up a 5 pack of the resistors and planned on installing them this weekend to see if they brought the supplies back to life...
      I looked over the power supplies to see if they were any different than the ones that didn't have the resistor. I didn't see any difference between them...
      • badcap111
        Xiaomi mi 9T missing resistor
        by badcap111
        Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
        I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
        Is...
        08-07-2023, 10:42 AM
      • liquidzorch
        Missing resistor on BQ ILIM pin. DA0P5JMB6D0
        by liquidzorch
        Hello. I can't find the schematics anywhere for this motherboard, does anyone have one, and can give me the resistor value for the BQ728H missing in pic below? I already read the dadsheet, and this resistor value is calculated, so I can't just go with whats in the "typical" diagram.
        On a second note, could this resistor cause it to only boot with the battery and not the charger? It boots fine with a charged battery, but will not turn on with the charger (nor charge). The 19v does not get past the first mosfet, it recieves pulses to turn on, but something is preventing it....
        12-18-2023, 01:56 PM
      • pete61
        Gigabyte 4080 Super Gaming OC with a resistor and three caps missing
        by pete61
        Hi all I have got a gigabyte 4080 super gaming oc with a resistor and three caps missing, Can anybody please tell me what the values for these are, See pic for details, Thanks in advance....
        05-21-2025, 09:46 PM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mugen1903
        da0x36mbae0 missing resistor
        by mugen1903
        Hello friends, the 0x36mbae0 model l motherboard is missing, there are resistors, I would like to thank my friends in advance who will help me with this issue.
        01-07-2025, 02:12 AM
