Re: Samsung Syncmaster 245BW
http://s807.photobucket.com/user/bud...?sort=3&page=1
Attached are pictures of the tabs on the bezel you will need to pry and pass
them by to remove the cover. There are 6 of these tabs on the top and
bottom ends and 4 on each side of the monitor. I have a home made bamboo
tool I use to go around the periphery of the cover and bezel to snap each of
these tabs away from the cover one by one. Once all of them are off the
cover you should be able to remove the cover easily. You can use two flat
blade screwdrivers in a pinch to remove the cover. I usually start the opening
of the cover somewhere near the middle top or bottom side. Use one
screwdriver to hold the initial position and a second one to go around the
periphery of the monitor. Good luck.Leave a comment:
That is why I request to to check the resistance on the Emitter and primary ground to see if there is shorted circuit or not since the Emitter is connected to the VCC pin of the PFC IC and the 24V SMPS IC.Leave a comment:
I get little progress. I put back QB801, and open JB805 which feed M_vcc to IC801S (SMPS IC), break the connect J808 which feed M_Vcc to ICM801, then between the primary ground and the QB801 Emitter read 7.2k Ohm, the voltage on Emitter is 17.56V now.
If one of jumpers connect, I would not get 17.56V on QB801.
Is it possible the IC801S and ICM801 both blow out?Last edited by sky007; 09-11-2014, 12:56 AM.Leave a comment:
Shorting transistor E and C, voltage on E show 0.18V, main Cap still only get 170V.
Something wrong.
Maybe we can say the transistor QB801 is good. The loads of M_Vcc get problem.Leave a comment:
Shorting transistor E and C, so the PW_ON would not need, and transistor E will be fed by AUX directly (17.56V), am I right?Leave a comment:
If you check the resistance between the primary ground and the Emitter, what do you get?
You can also force that transistor on by shorting the Photo transistor E and C together.
There is not much in that regulator circuit.Last edited by budm; 09-10-2014, 11:20 PM.Leave a comment:
I just do not understand why the transistor off board testing is good, but on board shows bad. Is any other component failure could cause trouble?Last edited by sky007; 09-10-2014, 11:15 PM.Leave a comment:
"330k" that is way too high, it should be around 100~1K Ohms. @330K, there will not be enough to turn on the PS_ON transistor.Leave a comment:
Yes, I have that document. It help me understand how it work. I find some different, but mostly part are same.
Yes, using a 330k resistor connect Sb and PW_On, so I do have PSON 3V signal.
With QB801 on board, Base 0.55-0.88v, Collector 0.7 - 1.4V, Emitter 0.6-0.9V.
Without QB801, base 15.61V, Collector 17.56V, Emitter 0V.
But test QB801 individually by multimeter, switch multimeter to diode test, read B-E 577, B-C 577, E-B 1, C-B 1, E-C and C-E both get 1. It looks good.
Anyway, I will change it first.Last edited by sky007; 09-10-2014, 10:21 PM.Leave a comment:
Are you supplying 3VDC to the PS_ON PIN?
The setup is really close to *-192 board (the designators are not the same but the connections are very similar). V ery similar to QB802 on page 1.Attached FilesLeave a comment:
To turn that transistor it should have Base to Emitter voltage of at least 0.6VDC.Leave a comment:
I think QB801 is bad. I take it out from board, and get reading from base 15.61V, Collector 17.56V, Emitter 0V.
But strange thing is, test QB801 off board, switch multimeter to diode test, read B-E 577, B-C 577, E-B 1, C-B 1, E-C and C-E both get 1. It looks good.
Can't find exact mode on ebay, but I find TIP41C 6A 100V NPN Transistor. Is it good as replacement?Last edited by sky007; 09-10-2014, 09:47 PM.Leave a comment:
I will do tomorrow and let you know. Thanks.Leave a comment:
Yes, that voltage should be there as long as the standby voltage circuit is working, so when you apply AC to the board, the voltage should be there right away, if not, check the resistor to see if it is open, it is <10 Ohms resistor for protection.Leave a comment:
The Collector is not getting the rectified voltage from the aux winding of the StBY transformer.
The output pin of the AUX winding is fed to resistor RB804, then the Rectifier diode DB80, the Cathode of DB804 is connected to the Collector of the transistor. We know the STBY circuit is working so you need to trace that out and see why you are not getting the DC at the Collector.
Cap CB809 (47uF 50V) is the filter cap for filtering the DC.Leave a comment:
Cap CB809 (47uF 50V) is the filter cap for filtering the DC.Last edited by budm; 09-09-2014, 11:50 PM.Leave a comment:
Then you need to check the Voltage on the Collector (metal tab) of QB801 that is the input pin, you are check voltage on the primary side so you have to use the negative leg of the main filter cap as the ground ref point. If you do have 15~20V on the Collector, then you need to find out if the Base - Emitter does show 0.6~0.7VDC, you have to make sure to supply PS_ON to the board to turn on this transistor.Leave a comment:
"the ICP801S (PFC IC) Vcc is 1V only which should above 15V. And the Vcc on IC801S (SMPS IC) is 14V" That does not make sense, QB801 linear regulator circuit (TO-220) Emitter is the output pin that has the output voltage directly to feed the PFC IC ICP801S (smd), and the 24V SMPS IC ICM801 (MC33067) VCC pins.Last edited by sky007; 09-09-2014, 10:55 PM.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by soopacrucialHi folks,
Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...3 Photos-
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
