150uF/450V replacement cap that is 18.5mmx40mm
  • Welchs101
    • Sep 2008
    • 979
    I am working on a monitor which needs a replacement "big" filter cap. The cap is 150uF/450V and the current one is ~ 18.2mmx40mm.
    The problem is when i go to digikey or mouser or newark.......the smallest they have is 25mmx30mm. The diameter is too big .........
    I must be doing something wrong when i go to these sites because for all of them the smallest they have is ~25mmx30mm.
    Can someone help?
  • Toasty
    • Jul 2007
    • 4171
    Re: 150uF/450V replacement cap that is 18.5mmx40mm
    You're doing nothing wrong. It's likely a special order cap for the manufacturer. Most in that value and close by are 22-25mm diameter.
    You could go to a 120uF/450v cap. It's at the low end of 20% tolerance of the original and would probably work just fine:
    Try mouser p/n: 647-UPZ2W121MHD - Nichicon UPZ2W121MHD - 18x40mm - $3.48
    Toast
    veritas odium parit
    • Welchs101
      • Sep 2008
      • 979
      Thanks. Do you really think a 120uF would work?
      On a similar question:
      If i had a 100uF cap (big filter cap) could i replace this with a 120uF cap (assuming both had same voltage specs)?
      • Welchs101
        • Sep 2008
        • 979
        Thanks. I will start a new thread for this 100uf being replaced by a 120uf cap.
        But back to this one..........so as a general rule of thumb.......one can go +/- 20% and you should be ok?
        • Toasty
          • Jul 2007
          • 4171
          As long as you stay within the +/-20% tolerance, you should be okay. Yes, you can put a 120uF in place of a 100uF.
          You can not, however, go down in voltage. But you can go up within reason. You can use a 475v or 500v cap for a 450v, but not the other way around.
          veritas odium parit
          • klkmalik
            seeking Tips
            • Nov 2011
            • 68
            • UAE
            Can someone help?
            this is very simple idea u caN USE(USED LAPTOP POWER ADAPTOR) IS MAIN CAP
            100 0R 150 UF /400 OR 450 I AM FOLLOWING THIS METHAD.
            • shovenose
              Source for quality stumpy 450v/150uF STGCON cap replacement
              by shovenose
              I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
              The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
              Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
              08-17-2021, 10:47 AM
            • cmlewis89
              LG 47LB5DF blown power supply board
              by cmlewis89
              Hi folks,
              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
              09-03-2024, 07:50 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
            • ezenia
              PS4 controller left stick potentiometer replacement issue
              by ezenia
              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
              09-30-2023, 02:19 PM
            • boosti45
              Macbook pro logic board replacement parts quesion
              by boosti45
              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
              08-21-2024, 05:23 AM
