Samsung S24C350 vertical stripes
  • thebluefox
    • Feb 2021
    Hi everyone! I have this Samsung S24C350 that I`ve gotten for less than 10$.
    The problem is that I have those vertical lines:
    The image is not always so dark as in the pictures. I suspect a bad display as the voltages seem to be normal.
    At the ribbon cable I measure 1-1.5 V on all the test points so I have signal from the main IC output.
    Unfortunately I cannot get the schematics for this display.
    I hope someone recognizes the symptoms as I am stuck at the moment
  • kotel studios
    Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
    by kotel studios
    Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
    In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
    08-06-2025, 02:07 AM
    09-07-2024, 05:50 AM
  • Raulnn
    Samsung UE65SL003AU vertical stripes
    by Raulnn
    I have a TV with a Samsung picture frame that suddenly got vertical stripes. can anybody help me. Will it be tcon or panel? thank you
    11-26-2023, 01:36 PM
  • Falki
    Colorful LCD Vertical Lines on Samsung ue55es8090
    by Falki
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    Sadly it has vertical lines at the left and one line in the middle-right.
    I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
    I have factory resetted the TV as well but also with no luck.
    I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
    A similar issue has been posted as well but also with no actual response ...
    08-12-2025, 04:19 AM
  • halen
    Hisense H55U7B vertical stripes
    by halen
    I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
    1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
    2. Connected only left side of LCD to tcon, big stripes
    3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
    Where could be problem?
    Tcon RSAG7.820.7932/ROH
    Main board RSAG7.820.8698/ROH
    Jan
    06-18-2025, 03:58 AM
