Recapping Acer AL1916 LCD Monitor
  • pradeep1
    • Jan 2010
    This is my first post on this forum.
    My trusty Acer AL1916 LCD monitor started developing the "blinking green power light and then coming on after 20 minutes" syndrome last week and the other day, it stopped working completely.
    I've been reading these two threads:
    https://www.badcaps.net/forum/showth...ghlight=al1916
    I've got bulged caps on the power supply board. I have ordered the full set of replacement caps, but one thing does concern me. There is a big fat capacitor in the middle of this board:
    https://www.badcaps.net/forum/attach...achmentid=9984
    It is turned away on my board (so I can't read the voltage and capacitance) and it is quite big and scary looking. Do I need to discharge it somehow, since I don't want to kill myself if I accidentally touch it during recapping.
    Please keep in mind that I am total n00b and I have never used a soldering iron before, so please explain everything regarding this in terms that a small child can understand. Haha.
  • Bobdee
    • Jun 2008
    • 461
    Re: Recapping Acer AL1916 LCD Monitor
    That big cap voltage is probably 400V and under normal circumstances discharges itself, but depending on the fault in your monitor occasionally it cannot discharge itself
    To check if it is discharged set your M/Meter to 1000 DC setting and put black lead on Negative terminal of cap and red lead on Positive and if discharged then there will be no reading
    Then to double check it, to ease your fears just cross the cap terminals with a screwdriver with insulated handle
    With your fault (bad caps) then I would guess there is no chance of it being still charged up (that is so long as you give it a couple of minutes to discharge itself)
    As for replacing that big cap, it is usually left alone due to it rarely failing
    Also for more help if needed Google (how to Discharge a Capacitor)
    • pradeep1
      • Jan 2010
      Thanks Bobdee for your input. Yeah, the board has been out of the monitor and sitting on my shelf for over a week now. I'll have to find my multimeter and check it out before fooling with it further.
      Thanks.
      • Radio Fox
        Acer AL1916 monitor PSU repair (DM0565R blown)
        by Radio Fox
        I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
        Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high,...
        04-13-2024, 06:32 AM
        by momaka
        03-15-2023, 10:17 PM
      • maralexbar
        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
        by maralexbar
        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
        If anyone knows how to force the external monitor as primary for Notebooks of those models
        11-02-2024, 09:18 AM
        09-06-2024, 05:27 AM
        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
        09-07-2024, 05:00 AM
