Samsung se650 1a1d1dpmm
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    hello anyone has bios dump for this monitor I have no video with DVI and displayport, menu doesnt work
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • Robby-Gr
    TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
    by Robby-Gr
    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
    Additional issues:...
    09-27-2025, 12:02 AM
  • glutton4punishment
    Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
    by glutton4punishment
    Samsung synchmaster 226BW.
    Before I replaced 5 caps, the screen was dim.
    Sometimes it wouldn't turn on.
    I opened it up, and found 4 bad caps in the pwr supply section.
    I unfortunately installee one backwards, i.e. wrong polarity.
    When I turned it on, I head a loud pop, and I quickly shut it off.
    The replaced caps are 3 860uF 25V's, and 1 330u 35V.
    One of the 860uF blew.
    I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
    03-18-2023, 12:49 PM
