I need hp pavilion 23xi bios dump
  • kingnizarios
    • Apr 2020
    • 19
    • Tunisie
    hi
    i need hp pavilion 23xi bios dump
    help me please
    • 20660
    Re: I need hp pavilion 23xi bios dump
    EEPROM EDID dump.
    • kingnizarios
      • Apr 2020
      • 19
      • Tunisie
      Originally posted by SMDFlea
      EEPROM EDID dump.
      thxxx man
      • kingnizarios
        • Apr 2020
        • 19
        • Tunisie
        EEPROM EDID dump.
        thxxx man
        do you have the full dump cause the reason of flashing the bios when i enter to setting the screen is blocked hdmi work and dvi and vga doesn't work
          • 20660
          No i don`t have it, its on some "paid" sites ,search for 0171-2281-4572 512KB bios
          • shomi75
            • Mar 2011
            • 7
            • Serbia
            Here
            • ghoshiry
              ghoshiry commented
              Editing a comment
              tank you bro
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
