Hello all. I have a 21" Sony Trinitron CRT monitor I'm hoping to repair. It's technically an SGI monitor, model GDM-5011P. I showed the attached pictures to a couple people who are slightly knowledgeable in monitors and/or electronics in general. And the general consensus is that it's an issue with the deflection board, or less likely the power supply. Most likely the deflection board though, as it looks like an issue with the horizontal sync. I'm hoping that it just needs a recap to fix it. The service manual complete with schematics, block diagrams and parts lists is available to view or download at https://www.manualslib.com/manual/99...Gdm-5011p.html
I've removed the deflection board (after ensuring the CRT was discharged and removing the anode cap from the tube), but don't see any visible signs of bad caps on the deflection board. Nothing bulging or leaking. But I know that caps can still go bad without exhibiting those symptoms as well. It looks like Sony primarily used good caps. The majority are Chemi-Con and Rubycon, along with a couple of ELNA's.
I'm mainly looking for advice on if this seems like something that could be caused by bad caps (or something else easily fixed). And if it is the caps, advice on selecting suitable replacements. Along with if I should pursue the deflection board (more likely) or power supply (less likely).
Here it is at the desktop:
And to rule out the PC itself, you can see it distorting the OSD with no signal:
Looking at Digi Key/Mouser, most of the caps are available in exact replacements (ie. Chemi-Con KMG series), or there is a designated replacement for older ones (ie. Rubycon KY replaced by PK series). Personally, for other projects I usually tend to stick to Nichicon or Panasonic. I also generally try to stick to only 105c caps for longevity. About half the caps on the board are 105c, and the other half 85c. So It would be nice to replace the 85c ones with a better cap, if possible. So I don't know if I should stick with these, or there is a better suited replacement.
Chemi-Con KHA x2
Chemi-Con KMF x1
Chemi-Con KMG x16
Chemi-Con LLA x1
Chemi-Con SMG x11
ELNA No Marking x1
ELNA RE3 x3
ELNA RJ4 x1
Rubycon YK x23
Rubycon YXA x1
And here are some general notes of mine:
YK replaced by PK
KHA replaced by KXG
KMF replaced by KXG
LLA = low leakage (doesn't seem available, and no replacement listed)
The one ELNA has no series marking, but has the same numbers written on the back as the RE3s do: 9849 85c
Thanks in advance for any info. I really want to get this monitor working again, as I more or less built my MAME cabinet around it. So throwing in any other display wouldn't fit well. And its been dead in the water for about 6 months while i was trying to find someone local to look at it. Which I couldn't find anyone.
-Nick
Chemi-Con KHA x2
Chemi-Con KMF x1
Chemi-Con KMG x16
Chemi-Con LLA x1
Chemi-Con SMG x11
ELNA No Marking x1
ELNA RE3 x3
ELNA RJ4 x1
Rubycon YK x23
Rubycon YXA x1
YK replaced by PK
KHA replaced by KXG
KMF replaced by KXG
-Nick
