Acer AL2021 bricks in menu
+ More Options
Posts
  • dondrusco
    • Apr 2009
    • 89
    Hi, everybody!
    I have Acer AL2021 with this symptom:
    When turned on, logo is bricked/unsharp (pic 1)
    Display is also bad (pic 2)
    I'm not able to turn off display then.
    I replaced all caps in power supply, but it didn't help.
    Then I replaced one 1000uF/6,3V capacitor in control unit. No change.
    There is problem with voltage on micro controller, I think.
    I measured voltage at 8051 controller - there were only 4,7V
    Which part have I to start with to check? (pic 3)
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Acer AL2021 bricks in menu
    Most of the time lines and artifacts in the display are the result of a bad connection to the panel.
    If you think voltage to the micro is causing it trace and disconnect that supply wire from the inverter to the main board then supply the voltage externally.
    Try to get a datasheet and verify what it's supply voltage is first though.
    • Toasty
      • Jul 2007
      • 4171
      8051 & "family" is 5v. 4.7v is fine.
      With "cut corner" of chip at TOP LEFT, Vcc is 7th pin to the right -> on top row. Ground is on bottom row, 5th pin to the right.
      veritas odium parit
      • Toasty
        • Jul 2007
        • 4171
        On second look, the chip to the upper right in picture may be the video processor "jungle". That's a BGA chip. This problem could all be due to bad solder on that chip.
        veritas odium parit
        • Krankshaft
          • Jan 2007
          • 2328
          If it is the BGA unless you're willing to take a chance with a heatgun to perform a ghetto reflow process then this monitor is hosed.
          • EGuevarae
            • Nov 2008
            • 1336
            I have a similar problem with another unit (AL2120) and I have been told by the original owner that the problem was narrowed down to the BGA chip. A heatgun can really help? I've seen the same suggestion for some xbox 360 failures due to loose RAM chips. It really can help on cases like this (and teh 360 ones) ?
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • Windows 10 Pro x64
            • GeForce GT1050
            • dondrusco
              • Apr 2009
              • 89
              OK, I try to reheat with heatgun. I have experience with reheating nVidia Geforce 7x00 Go chips in HP Pavilion dv6000/dv9000 notebooks. I try to do the same way.
              • Toasty
                • Jul 2007
                • 4171
                I had a Dell Latitude D800 in here a few weeks back with look-alike screen issues. Sometimes immediately, sometimes after a few minutes. Got it apart and found I could press on the video card and make it worse.
                I tried this procedure for a "ghetto reflow" and the problem partially resolved. It would stay on as long as you didn't press on the board. Determined that the RAM chips (4!) also needed it done. Much too small an area to work in and would have required a very precise heat shield as many components were within 4mm of the chips. The owner procured another unit from the pile at work and I ended up just swapping the cards.
                I used this procedure for a ThinkPad as a guideline and winged it from there:
                http://forum.thinkpads.com/viewtopic.php?p=386104
                Toast
                veritas odium parit
                • dondrusco
                  • Apr 2009
                  • 89
                  Thank you, Krankshaft!
                  I reflow BGA memory chip - now the monitor works!
                  I will be more careful on the next time - 4 caps went bulged (not so much) - heat came under aluminium cover.
                  • dondrusco
                    • Apr 2009
                    • 89
                    After one week of working monitor went down again.
                    I tried to recap, but no change.
                    I connected it to external power supply, with extra +5V connection, instead of 12V/5V regulator on main board. I was not able to turn it on.
                    When I used 12V only, I was able to turn it on.
                    I try to push BGA memory chip - no change. Main chip MST9251- no change.
                    But when I pushed microcontroller, monitor dead.
                    I try to reflow it - probably cold join under it.
                    • dondrusco
                      • Apr 2009
                      • 89
                      Monitor is back again! I reheated all three chips. I will do more stress test on it.
                        LCD LED TV Service Menu Codes
                        ALL LCD LED TV SERVICE MENU CODES
                        Service Menu Code with Board Name
                        China Universal Board / Jumper Board Service Menu Code
                        Changhong Ruba Service Menu Code
                        Ecostar LED TV Service Menu Code
                        Orient LED TV Service Menu Code
                        Haier LED TV Service Menu Code
                        TCL LED TV Service Menu Code
                        Samsung LED TV Service Menu Code
                        LG LED TV Service Menu Code
                        Videocon LED TV Service Menu Code
                        Supra LED TV Service Menu Code
                        Toshiba LED TV Service Menu Code
                        Symphony LED TV Service Menu Code
                        Veste/ LED TV Service Menu Code...
                        10-31-2024, 03:58 AM
                        09-06-2024, 05:27 AM
                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 05:00 AM
                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                        This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 04:10 AM
