Quick question on Panasonic series caps
  • torin3
    • Aug 2009
    • 178
    I got 2 more monitors to fix tonight, and I just ordered the replacement caps for them. Should be an easy fix. They both had obvious bulged caps, and their first problem was not turning on.
    I've been getting FM series Panasonic caps, but one of them, 0.47uF, 50V wasn't in stock at DigiKey in the FM, or the FC series. They did have it in the EB series, so I ordered that.
    Am I likely to have any problems with it? The old cap looked good, and I can put it back in if necessary.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Quick question on Panasonic series caps
    Yes I if the lower values aren't available in the low ESR series a General Purpose series will be fine.
    If you measure the ESR on these low capacitance caps they will most likely be in the 10-15 ohm range new anyways.
    I've used the EB series myself a few times and didn't have any trouble. I was purging all of the Fukyuus in my Antec.
    • etnietering
      • Apr 2009
      • 379
      Yeah I used Panasonic EB for the little caps in my router (post 6), and it's still working fine several months later Good luck!
        master hoarder
        • May 2008
        • 12170
        Since you're ordering from Digikey, PW and HE from Nichicon as well as KY, KZE, LXZ, and LXY from United Chemicon are all about the same or better in specs than Panasonic FC.
        With a 0.47uF 50V cap, though, I doubt you will have any problems using Panasonic EB.
        • torin3
          • Aug 2009
          • 178
          Thanks for the help and suggestions. Always good to have backup options.
          • bulkchart32
            i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
            by bulkchart32
            i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
            06-16-2025, 03:09 AM
            by momaka
            03-15-2023, 10:17 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • icanic
            Panasonic TX-C81 Pro series vintage tv help.
            by icanic
            Hello ppl!
            Can someone help me where to start with repairing this CRT TV. I have an old vintage PRO series CRT TV from Panasonic, model is TX-C81, cant find any schematics online. I will post pictures with the problems.
            If someone could please tell me where could I start searching to solve the problems and what could be the cause of the problems.
            As you can see all colors are bleeding, it have white glow on black and that white cube is not straight at the top.
            But the main problem for me are the colors and white glow
            ohh and when brightness is a little bit...
            01-22-2024, 12:39 PM
