Display stand spring tension
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Is there any way to adjust the tension of the suspension springs in these monitors? Or, are they "custom designed" for the weight of the monitor they are tasked with supporting?
    • 31214
    Re: Display stand spring tension
    what monitors?
    i know the older HP stands had springs that more than matched the monitor and they where held back so-to-speak by bolts with nylon-liocking nuts to act like a friction brake.
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Originally posted by stj
      what monitors?
      ANY monitor (with an adjustable stand).
      It appears that the stands are unalterably mated to their particular monitors (e.g., a stand for a small monitor will never support the weight of a larger one).
      [I'm always leary of "unwinding" springs without knowing what to expect]
      • DXseekerMO
        Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
        by DXseekerMO
        Hello everyone!
        Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
        Symptoms:
        1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
        2) TV does not appear to turn on
        3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
        4) "Power on" terminal on Power Supply has 3.26v
        5) "A13V" terminals have 12.9v
        6) Stand-by test jumper on Power Supply has 12.9V
        7) Optical audio jack on Main Board illuminates
        8) With stand-by...
        06-09-2021, 12:19 AM
      • FriedFred
        Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
        by FriedFred
        Hello, everyone!
        I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
        I took out the memory and the battery and the SSD.
        So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
        After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
        After several seconds, the fans switch-off and the board keeps powered...
        03-08-2025, 04:45 AM
      • Titus6
        LG OLE65C1 Stand-By issue
        by Titus6
        I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
        However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
        I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
        01-31-2025, 04:01 PM
      • ChaosLegionnaire
        correct way to connect bare speaker wires into spring clip terminals?
        by ChaosLegionnaire
        i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
        however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
        i googled...
        10-27-2022, 06:19 AM
      • DXseekerMO
        Vizio E400i-B2 missing stand-by voltage
        by DXseekerMO
        I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
        So I took some voltage readings upon the original board. Here's what I found:
        Main caps have 169.9v
        AC detect voltage is 1.3v
        None of the MOSFETS appear to be short.
        The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
        10-30-2021, 10:19 PM
