Samsung Syncmaster 740N
+ More Options
Posts
  • Levistus
    • Aug 2009
    • 5
    Hi. My Monitor does not display anything. Sometimes It works if I leave it on for a day or 2 but when I turn it off for a while I have to leave it on again for days. It gets worse every time I do this. What seems to be the problem? Thanks.
    front
    back
  • Bobdee
    • Jun 2008
    • 461
    Re: Samsung Syncmaster 740N
    Bad capacitors, top right of picture (2)
    Bulged on top (like small dome)
    • EGuevarae
      • Nov 2008
      • 1336
      I agree. Replace the set of caps on the upper right corner of first pic.
      And Welcome to the Forums
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • Levistus
        • Aug 2009
        • 5
        Thanks a lot guys! How much do those capacitors for my monitor usually costs and where can I usually buy them? This is the first time I will fix a monitor on my own. Thanks again.
        • Gianni
          • Jul 2008
          • 681
          • Italy
          Hi Levistus
          if you have a solder and you can replace the bad caps it will cost you few $, it depends on where you live.
          You can buy caps from this site, ask to Topcat or you can read this thread.
          Ciao
          Gianni
          "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
          H. J. Brown
          • Levistus
            • Aug 2009
            • 5
            How do I know what type of capacitor I should buy? I'm from the Philippines and this is where I will buy http://philippines.rs-online.com. Thanks.
            • PlainBill
              • Feb 2009
              • 7034
              You want a 'good' brand high temperature (105Β°C), low ESR; I prefer Panasonic FC series. I note that RS carries them. Their web site is not real good for selecting parts, but that can be worked around.
              How about we do this: List the following information on the capacitors you want to replace: Capacity, Voltage, Diameter, Length, and quantity. You can either look the parts up on the RS web site and post what you believe are the proper parts, or you can simply list the above information and someone (possibly me) will list the replacement.
              PlainBill
              • Levistus
                • Aug 2009
                • 5
                How do I find these information? Are they written at the side of the capacitors themselves? or should i look the capacitor name in my monitor? i"m going to check the capacitors after i post this. Thanks!
                • xtraelectronics
                  • Apr 2009
                  • 49
                  The values are clearly stated on the side of the capacitor. Be sure to get the same V rating (voltage, or a bit higher ok.) The uF value should be the same (I have used slightly more capacitance, but sometimes this will cause issues, so stick with the same value). There is also a temperature rating. ALWAYS use 105 dgreee caps in these and all modern electronics! Hope this helps.
                  • Levistus
                    • Aug 2009
                    • 5
                    ok 1000uf 10v and 105 temp. how about the diameter and length? thanks
                    • PlainBill
                      • Feb 2009
                      • 7034
                      I use a small ruler. Usually you can measure them while they are still in place.
                      PlainBill
                      • vincentedel
                        Samsung SyncMaster 740n Phase Control Issue
                        by vincentedel
                        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                        04-22-2025, 12:33 AM
                        09-07-2024, 05:50 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
