Backlight problem on a AL1916W
+ More Options
Posts
  • IRShifty
    • May 2009
    • 78
    I received this power supply board from a guy who wanted a repair on it. I replaced the two caps you see in the picture. I gave the power supply back to the guy, but he had the whole thing taken all the way apart. After reassembly it doesnt go together just right but it does now it power on just fine. Their is still however a problem with the backlights, they do not power on at all. The image can be faintly seen with external lighting. Now I did some research about a fuse keeping the backlights from powering on.
    I don't have a lot of experience in fuses but if the red and green circles are fuses then when i test the green one for ohms it passes and the red one does not.
    For the Mosfets, the blue one receives ohms through all 3 pins and the pink one does not.
    If any of these things would apply to my current problem please let me know. If you think it is something else then lets hear it.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Backlight problem on a AL1916W
    Been there, done that. This thread has all the details.
    The two components you circled are resistors. The drill is simple. Replace both mosfets, replace the fuse, replace the caps. The fuse is a smd type on the copper side of the board. IIRC, I used a 4A fast blow. The mosfets are available on eBay.
    Question: What caps did you use as replacements?
    PlainBill
    • IRShifty
      • May 2009
      • 78
      Thanks for the fast reply Plainbill
      I was reading that thread through before I made this one but did not see much about the backlights. I have had your ebay link to the mosfets open for awhile so I have that. Do you think I need to replace the fuse? or only if it is bad? For the replacement caps I used on hand crappy ones. aka radioshack, but they work for now.
      • IRShifty
        • May 2009
        • 78
        Also, do you know of anyone that has a tutorial or a guide or anything like that on disassembling/reassembling this monitor? I would prefer if it was back together properly. If not then its okay. all the parts will be inside and working.
        Edit: reading through the first thread again i am seeing plenty about the backlight. I guess i was in a hurry before. Now i feel dumb for starting a new thread =X.
        • PlainBill
          • Feb 2009
          • 7034
          Excuse me while I embark on a minor rant.
          There is a famous proverb "It's a poor workman who blames his tools." Like most proverbs, it is only partially true. The most important asset for any workman is his mind. But even a genius needs some basic tools. Fixing monitors isn't difficult, but you need screwdrivers, a soldering iron and solder, wire cutters, and a clear place to work. You also need a multimeter. A cheap VOM will do, although I prefer a move versatile DMM. OK, rant over.
          I don't know if it is necessary to replace the fuse. Is it open? If it is, replace it. If it isn't, don't. Use your VOM or DMM. If you don't have one, buy one.
          On an additional note, I recently repaired an identical monitor. The damage consisted of: Two caps with bulging tops, a shorted FET, and a blown fuse. I also replaced the rest of the caps because they are a known bad brand and the additional cost was minimal. After I removed them, I tested them with my ESR meter. The two from the inverter failed, the remainder passed.
          My conclusion is this inverter has a poor design that stresses the caps. When the caps fail the FETs take an additional load and one or both will also fail, blowing the fuse. Unless you enjoy replacing failed capacitors, shorted transistors, and open fuses, do NOT use inferior capacitors. If for no other reason, consider your reputation.
          PlainBill
          • EGuevarae
            • Nov 2008
            • 1336
            PlainBill
            I have repaired some units that use that very same PSU/Inverter board (Acer and Westinghouse), and as per PCBONEZ suggestion, I replace the MOSFETs in pairs even if only one failed. As per the fuse, it is/was always blown. And for the caps, you are already there, so change them all just as a precaution, as the cost is minimal and you might avoid reopening the unit again just for another cap (especially when the caps are a known bad brand).
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • Windows 10 Pro x64
            • GeForce GT1050
            • IRShifty
              • May 2009
              • 78
              alright alright, ill stop being lazy and open the wallet to save time =)
              • EGuevarae
                • Nov 2008
                • 1336
                • GeForce GT1050
                • dondrusco
                  • Apr 2009
                  • 89
                  I have the same issue - and step-by-step I found, that:
                  1, two 220uF/25V caps bulged - exhcanged all
                  2, fuse Fxx1 blown - I decided to use 3,15A
                  When fuse was changed - backlight starts 'clicking'
                  3, one of 40T03GP MOSFET-s dead (shorted)
                  I decided to exchange both FETs - as you suggest.
                  • Dobrowol
                    Asus GA402RK keyboard and kb backlight problem
                    by Dobrowol
                    Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                    04-28-2025, 04:30 PM
                  • ononos
                    LG M2362DP Backlight problem
                    by ononos
                    hello everyone!
                    As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                    I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                    So i decided to try to...
                    03-12-2023, 05:05 AM
                  • fanaticgames
                    Samsung UE32D4010 Backlight problem, led ok
                    by fanaticgames
                    hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                    02-22-2023, 09:46 AM
                  • grbo92
                    Backlight problem Acer LA-031P
                    by grbo92
                    i have one acer Nitro 5 without backlight on my desk.
                    Mainboard model: LA-L031P GH53Z REV 1B
                    Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                    11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                    Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                    Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                    09-09-2024, 03:49 AM
                  • szogun
                    Weird problem with keyboard backlight in Thinkpad T470
                    by szogun
                    I`ve bought two T470, both of them has a backlight keyboard, and in one of them (lets name it computer A) it doesn`t work.
                    There is no "welcome light up" and no reaction to Fn+Space combination. My first suspect was the keyboard itself, so after checking the connectors, cleaning them na ribbons which didn`t help, i`ve swapped the keyboard as i have second computer (lets name it B)
                    From now, things are getting weird.
                    Both of keyboards started to work as it should. Welcome light up, switching on and off, changing brightness etc.
                    Computer B with keyboard...
                    10-02-2021, 02:08 AM
