AOC 2216Sa monitor displaying weird colors.
  • PopcornMobo
    • Dec 2017
    • 53
    • Lithuania
    I found this monitor at the dump right when i was in the need of one.
    The monitor is not smashed and works fine.
    The lack of "LED" stickers on it tells me that it's got CFL in it.
    One thing about it is that it's displaying colors wrong.
    It's like there's these very rough transitions between various shades of colors, almost as if there's only about 32 colors.
    Also every second vertical line of pixels is darker where the image is also dark.
    The only example to describe this i can think of would be maybe a compressed image.
    Now that i think of it i also have a TV that also displays colors in the exact same way and that TV also happens to have CFLs in it.
    I remember something similar to this happening on my SONY laptop, it had a failing CFL tube in it and would occasionally display the image wrong, i bodged a LED backlight from another screen in it and it's been working fine ever since, could this be related?
    One bad thing about this screen is that it's a pain to take apart, the plastic from the back comes off easily but the PCB is behind a sheet metal frame that is attached to the LCD assembly, this prevents me from easily checking the caps.
    Another thing is that the aforementioned TV does the same thing but all the caps in that one are good.
    My guess is that the CFLs are old and the HV drivers are working overtime and in turn end up causing EMI, which then messes with the image processing.
    I can kind of sort of try to take a picture of the screen to show what it looks like.
    Any ideas?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: AOC 2216Sa monitor displaying weird colors.
    phone camera might get a good pic .
    • PopcornMobo
      • Dec 2017
      • 53
      • Lithuania
      I updated the original post.
      It's hard to get a decent picture of a screen without aliasing, but the one i got looks good enough.
      The red in the windows logo shows the dark vertical lines well and the blue shows the bad transitions between shades of colors.
      It's like the screen is trying to display the image in a compressed/low-bit mode.
        by momaka
        03-15-2023, 10:17 PM
      • wattage
        AOC AG493UCX 49-inch monitor - Firmware request
        by wattage
        Hello Badcaps Community,
        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
        by Rick_1234
        Good evening, gentlemen.
        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
        https://drive.google.com/file/d/1L6S...ew?usp=sharing
        Things I tried
        - Bought a new AC adapter thinking that was the problem but the problem...
        06-22-2024, 04:44 PM
      • Ifixstuff9
        Dell SE2416h monitor power cycles - very weird behavior
        by Ifixstuff9
        Hello all,
        I have a dell SE2416h monitor that power cycles at somewhat random intervals. When the monitor is first powered on after being off for a few hours, it lasts 15-30 mins before the first power cycle. After that, the cycles progressively get more frequent until the monitor cycles every few seconds.
        I'm not sure what is causing this, but maybe something is overheating, causing the monitor to shut off? That would explain why it gets worse with time.
        Now here is where things get weird (at least to me, this might be some some common symptom I've...
        04-20-2019, 07:03 PM
