Broken Dell 1800FP Power Supply - when and when not to resolder?
  • EricRepaires
    • Jan 2021
    • 11
    • Zambia
    #81
    Re: Broken Dell 1800FP Power Supply - when and when not to resolder?
    Originally posted by Bobdee
    Sorry lads messed up somwhere with above link, will try again,
    cant understand why other link dont come up,
    bob
    Hey
    I was wondering If you could help me the Power supply Pdf Plz
    • EricRepaires
      • Jan 2021
      • 11
      • Zambia
      #82
      Hello Maverick
      This Schematic will help you and Plainbill sort your problem out with luck, Its not for your monitor but its your p/suppy to a T.
      Also my problems with FP1800 was,
      AC input fuse, 0.33 resistor (R923), Mosfet on H/sink that resistor goes to, and power controller ICE2AS01, along with a lot of bad solder joints, particulary the diodes on H/sink that you mention, this may help you,
      bob
      This Link Ain't Working
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
