Replacing a bad logic board
  • andy29
    • Jun 2018
    • 3
    Hello, I have a Yusmart 229IP-P 22" monitor, and when I plug in the power, it turns on and locks up with a black screen and the backlight on. With no signal the power LED never indicates it going into standby like it should, and giving it a signal or pressing the buttons (including on/off) does nothing at all.
    I'm suspecting the input/logic board has failed in some way because I've had a look at the power board and the capacitors, voltages and connections coming from it, and they appear to be fine. I was also using a PSU which was having odd problems at the time the monitor died, almost like an incorrect voltage has found its way out through a PCI-E graphics card VGA port. I'm not sure if that's possible without having anything else blow up!?
    There is someone on selling used boards with the same model number as the one from my monitor on AliExpress, and it looks exactly the same except that it has a DVI port and a VGA port - my board only has VGA. But since it's on the input/logic board I wonder if it would be ok - do you think it might work if I fit it to my monitor? (Or have any thoughts of things I could check before I try replacing it.)
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • ohren
    by ohren
    09-08-2023, 05:24 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
    by momaka
    03-15-2023, 10:17 PM
  • korben_dallas
    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
    by korben_dallas
    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
    MY QUESTION:
    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
    02-14-2024, 12:23 AM
