Dell (sony) P991 trinitron troubles
  • mrmazda
    MrMazda
    • Sep 2013
    • 115
    Re: Dell (sony) P991 trinitron troubles
    Originally posted by jdimpas
    Remove the Socket board in the tube and find R459 its actually a 10M ohms resistor.Then go to the market and grab some 4.7M~5M resistors, removed the 10M ohms (R459) then replaced it with 4.7M~5M. Solder it and return back the socket board in tube, just be sure that all cables are plug back. Then turn on you monitor! It should work
    I was less than thrilled with both auto reset and DAS results on my P991, and its socket board is different. I don't see any R459. Is there a resistor fix for this one?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • sviru
      Dell P1110 Sony G500 Trinitron fix - not brightness!
      by sviru
      Hi guys I have issues with my "new" P1110.
      The screen is not horizontally centered. From the start. I need to shift the screen and make it bigger to fill the screen. No matter what source xbox/pc/laptop.
      There is also a big distortion you can see here.
      https://ibb.co/NCGKs7N
      Also the screen has a little red shift in the blacks.
      Any ideas? Screen is not too bright.
      08-30-2023, 08:03 AM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • cmonkey
      Sony Trinitron KV32FV27 Suddenly Dimmed
      by cmonkey
      A couple of days ago I finally got my hands on a locally sourced Trinitron and after lugging all 175 LBS home I gave it a good cleaning inside and out. The guy said it had been in a shed for 2 years, but the outside wasn't too bad. The inside was another story and while there was no evidence of mouse, it had certainly been kept in a VERY dirty home.
      I cleaned it to an acceptable level of grime, at least clean enough to where nothing would heat up from the dust insulation. I then tried it out and it worked!
      I'd say I had it on for about 15 minutes or so and then lugged...
      04-28-2023, 06:25 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
