The infamous 2 seconds to black
+ More Options
Posts
  • shimjocky
    • Mar 2009
    • 31
    #61
    Re: The infamous 2 seconds to black
    Got the transformer off and the readings are the same as before.
    • PlainBill
      • Feb 2009
      • 7034
      That is definitely a problem. Usually the secondaries will match to within 1% or so. A 10% difference is a sure sign of problems. You have a 4:1 ratio.
      Replace it.
      PlainBill
      • shimjocky
        • Mar 2009
        • 31
        #63
        Thanks PlainBill. I will get the new one on order asap.
        If you don't mind a follow up question regarding the transformer I would like to ask if one secondary is bad can it keep the other side from working as well?
        When I got these readings I kind of thought that the lights powered by the good side of the transformer should work. Granted it was an uneducated assumption, just curious.
        • PlainBill
          • Feb 2009
          • 7034
          It depends on the design of the transformer and the inverter itself, but usually, a failure affecting one tube will shut down the entire backlight system.
          A brief summary of what happens when an LCD monitor is turned on. The logic card sends a signal to the inverter controller to turn on the CCFLs. The inverter controller turns on the CCFLs at full power. A fraction of a second later it begins checking the voltage across and current through each CCFL. If any are out of spec, the inverter controller shuts everything down - two seconds to black.
          NOW, some designs do not check both current and voltage. Or they may do only a partial check - shut down only if the voltage across a CCFL gets too high. And some (those inverters used in case lights don't check anything!
          PlainBill
          • shimjocky
            • Mar 2009
            • 31
            #65
            Thanks for the lesson, much appreciated.
            • MegaOne302
              • Apr 2009
              • 94
              #66
              From my very limited knowledge, 3 main things that go bad. 1 a CCFL tube, you'll see black ends. 2 a bad cap, they're usually bulging. 3 a bad Scotty diode, these guys turn gray or start cracking.
              Oh ya, let's not forget a blown fuse.
              Does an idiot make a sound if no one’s there to hear them talk?
              • attrib
                • Oct 2011
                #67
                I want t say that My Acer AL2223W had the same problem and it WAS he transformer ( SPI 8TC00332 ) So I just had a old used ACER monitor with scratched screen and it that had a transformer ( SPI 8TC00245 ) inside. So i used that one to replace my transformer that had a 2.5K ohms on one side and a 1K ohms on the the side side.. Both sides should have no more ten 1K ohms reading on both secondary windings.
                If you need a new transformer or SUB replacement. you can also use ( MS220T )
                Check here
                http://www.lcdparts.net/TransformerD...ProductID=2796
                Anyway as long as the transformer has the same readings it should work proper. I just did this fix today.. it was perfect...
                Oh one more thing.. Remember to have a signal going to the monitor from your computer.... This way the lights of the screen will stay on... otherwise it will time out.
                TAKE CARE ALL
                Cheers from Canada...
                THE END
                • vokwok
                  • Sep 2011
                  #68
                  I have Fujitsu siemens monitor with same guts like this acer
                  and problem is also 2 seconds to death.
                  when monitor is turned on there will be very good picture from computer for 2 secs and then it goes blank. I have replaced all caps and i did measure the transformer and fuses too. could someone give me a hint what to look next?
                  and i did use vga and dvi input and there are no diffrence between them.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Substitute known good CCFLs.
                    PlainBill
                    • vokwok
                      • Sep 2011
                      #70
                      area you saying CCFL are broken or even one of them is broken ?
                      what is easyest way to test these CCFL ?
                      should the monitor stay on if i dont connect CCFL connector's to board?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        First, let's verify one thing. When you turn on the monitor you get a display for about two seconds, then the display goes blank, but the power LED stays green? That is two seconds to black, which has several possible causes.
                        You have replaced the caps. Did you use low ESR caps?
                        You have measured the transformers. Did they match to within 3%?
                        The next likely cause is a bad CCFL, or wiring to the CCFLs. Some monitors are notorious for bad solder joints at the CCFLS, or frayed wiring. A broken CCFL is also possible. The easiest way to test that is to substitute a set of known good CCFLs. They don't have to be installed in the LCD panel, I use a pair that are in the reflective channel.
                        The last possible cause is a defective component in the protection circuitry; testing that is very difficult.
                        PlainBill
                        • vokwok
                          • Sep 2011
                          #72
                          yes led stays on.
                          and yes i did use low ESR caps
                          and yes i did measure transformer's both sides and it did match. both was very near 1kOhm
                          i did check solder joints and now i need to change CCFL to working one's.
                          • ChIck3n
                            Dell u2311h 20000 seconds to black issue
                            by ChIck3n
                            So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                            09-09-2024, 11:44 AM
                          • DrankinSAW
                            LG 37LG5020 and the tale of 2 seconds to black.
                            by DrankinSAW
                            I bought an LG 37LG5020 with a very strange issue.. it turns on, the display looks fine, but still, after 2 seconds, the TV shuts the backlight off..
                            However, if i leave it plugged in for 20-40min.. the time it takes to shutdown the backlight, doubles (to 4 seconds)..
                            I bought a new inverter, set to arrive on December 13th
                            11-22-2023, 01:10 PM
                            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                            09-12-2024, 02:00 PM
                            MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                            This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 01:58 PM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:00 AM
