Asus PB279Q working but no image.
  • xenio
    • 7
    • Italy
    I have an Asus PB279Q and there is no image displayed but the panel is gray I can see the led panel is on the backlight is working, the monitor looks like it is working ok, in Windows I can see that it is recognised, if I change the resolution the screen respond but always with no image, the power button is on and stays on.
    With a flashlight I can't see any image.
    At the boot there is no ASUS text displayed, the panel light on without any image, pressing the buttons there is no OSD on screen.
    Already tested: cables, different pc, power on/off etc.
    The caps looks ok, no evident sign of bulging.
    I was looking for the fuse but I can't find it.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Asus PB279Q working but no image.
    It's possible that this is a T-con board issue. The T-con board is attached to the LCD TFT panel and is usually located at the top of the monitor under a metal shield. Once you find it, please post some pictures of it. While at it, there should also be a fuse on the T-con board near the LVDS connector. If you have a multimeter, check if it's good. Once we have some pictures of the T-con, we should be able to give you more things to test.
    • xenio
      • 7
      • Italy
      Thank Momaka, the pictures of the tcon board are already on the first post.
      • piernov
        • Jan 2016
        • 4437
        • France
        The pictures you posted are from the mainboard.
        momaka wants to see the board that is at the other end of the FFC, connected in the connector labelled "eDP" on the mainboard.
        The other board should be as large as the panel and either at the top or the bottom of the monitor.
        Once you find the other board, somewhere next to the connector will be an SMD component which is the said fuse. It may be white, or with a single letter labelled on it. You should check for continuity across this fuse.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Exactly!
          Thanks for clarifying. I though I replied to that, but not sure what happened to my post. Anyways... yes we need pictures of the T-con.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 944
            Xenio: If you need to see what the Tcon panel may look like take a look at the pictures in this post and you will see what Momaka means:
            https://www.badcaps.net/forum/showthread.php?t=66882
            • xenio
              • 7
              • Italy
              Oh... I get it, I didn't notice the board (tcon) on the back of the panel.
              The monitor is so slim that I didn't check on the other side of the connector.
              The good news is that the warranty for the PB279Q is 3 Years! and Asus sent me in a couple of days a refubished working monitor
              Probably as you all said the problem was the fuse on the tcon.
              • DynaxSC
                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                by DynaxSC
                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                The behaviour is also really very strange, i.e.:
                • The disk shows always up in BIOS - so it is recognized, so far so good
                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                02-23-2025, 01:33 PM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • rayshine03121408
                I Need Working BIOS for ASUS E410MA R7.1
                by rayshine03121408
                Good Day Masters! Anyone have working bios for ASUS E410MA? i tried reading the BIOS Chip and the programmer cant detect it i think the bios chip is dead... i already tried 2 programmer but same still cant detect the chip. Thanks in Advance
                Model: ASUS E410MA-TB.CL464BK
                SN: N8N0CX06E199324
                BoardModel: E410MA R7.1
                Yesterday, 05:36 AM
              • rheyntau
                ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
                by rheyntau
                CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
                07-06-2025, 07:22 AM
              • Mani .H Soltani
                Hello guys/gals i really need a working BIOS for this Asus E203NA Rev3.0 laptop please help :)
                by Mani .H Soltani
                Now then SMD before we start our usual Cat & Mouse game the Board im requesting a BIOS for is different then the existing thread and the thread isnt about a no POST asus its about adding Serial number to working Asus so please for the love of GOD don't merge/delete me this time.
                So my problem is that it don't work nothing i tried a dump it powered on once and ... no display no POST and with OG dump its dead in the waters so can anyone please help with this file ?
                Laptop is a Asus Notebook L203NA/DS04
                With a E203NA REV3.0 MB
                S/N L8NOCX00240534B
                No Service...
                06-08-2024, 10:47 AM
