Samsung 24" BN44-00195A PSU Issue
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Hi, recently my Samsung 2493HM failed to switch on, the blue power led keeps blinking fast and faintly. Measurements indicate that 5V Standby line is stable until the PSU gets the turn on signal, all lines become unstable at that point and begin oscillating at regular intervals, dropping voltage pretty much to zero then recovering (including the 5V standby line as well that was stable before turning the PSU fully on). All caps are fresh, nasty chloroprene glue removed everywhere, main components checked (mosfets, diodes, big cap, other caps). The voltage of the main cap is about 320V at all times.
    This happens even without any load connected to the PSU.
    Any wild guess about going forward? Don't wanna make a mess with the 320V hanging around...
    Included a PDF schematic in attachment. Cheers!
  • petehall347
    • Jan 2015
    • 4440
    Re: Samsung 24" BN44-00195A PSU Issue
    controller chip area maybe . or a short .
    see if a particular voltage drops first .
    thats my guess ..
    • FrozenHaxor
      • Jun 2015
      • 260
      • Poland
      Scratch that, the logic board is dead as well, main chipset fried. Something went horribly wrong with this one. Repair not cost effective and not worth the effort.
      I consider this thread closed. Thanks for suggestion though.
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
        09-07-2024, 05:50 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
