Wacom cintiq dtz-2100 power issue (need ideas)
  • chicago77
    • Oct 2014
    • 15
    Good evening. I figure you can find anything on the internet, but I've been stumped.
    I have a Wacom cintiq 2100k I acquired that randomly powers off. When you let it sit for a while unplugged it powers up generally on the first try and will stay on for a few minutes. It then goes completely dead (no lights). If I wait, it normally comes back on after a minute or so and then repeats. Generally it powers off faster and stays off longer if I leave it plugged in.
    I've done some debug by unplugging boards one at a time and I believe I have narrowed it down to the middle board that has the 12V input and DVI plug. Nothing looks obviously bad and the 12V in seems to be good.
    I was thinking about replacing the DVI chip (gm5862h-lf AA) but I haven't found a place to order it, nor do I know if it has any vendor loaded code on it. Does anyone have familiarity with this chip? There 2 SDRAM chips next to it I assume it boots from. I was also considering hitting the oscillator with some LN2 to see if it was failing as it heated up. Nothing really seems to be getting too hot.
    Does anyone know where I could find a replacement board? I checked ebay and was shocked there was nothing there.
    Id also love to just fix this board if anyone has any ideas. I have access to a re-flow machine. So I should be able to swap any part on the board if I can get it. Do you guys have any idea what I should look for to narrow it down? I'm pretty handy with a multimeter, but am lost without a schematic.
    I really appreciate the help, thank you =)
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Wacom cintiq dtz-2100 power issue (need ideas)
    Take some high-res picture of the board.
    Sounds like an overheating issue, maybe a voltage regulator on the board you're talking about.
    • chicago77
      • Oct 2014
      • 15
      Sorry I totally forgot to add them.
      • piernov
        • Jan 2016
        • 4439
        • France
        I see some discoloration around IC7, but I don't see any markings on this chip?
        Anyway, check the voltage on all its pins when it's working and when it stops to work.
        • chicago77
          • Oct 2014
          • 15
          IC7 Has readouts of GND, 1.8V out, and 3.3Vinput when the unit is working and 0V all around when it isnt. The other voltage regulator is 6.2 adj, 12V input, and 12V output when the unit is working and when it is not.
          The inductors on the left is measuring 4 volts and the one of the right is at 3.3.
          • chicago77
            • Oct 2014
            • 15
            It appears the board looses all 3.3V when it is not functioning.
            • piernov
              • Jan 2016
              • 4439
              • France
              Ok so you would need to trace the 3.3V line to check where it's coming. Since you mention 3.3V at the coil on the right, I guess it comes from somewhere near that, maybe IC6. What are the markings on this chip?
              I still find it strange that IC7 has so much discoloration around it, it may need to be replaced.
              • chicago77
                • Oct 2014
                • 15
                I'll try to check on that when I get home. The discoloration is not as evident in real life, I think it may be just some flux residue that is getting picked up by my camera. Ill try to take a few better photos as well.
                • chicago77
                  • Oct 2014
                  • 15
                  IC7 - M35L 1117-18
                  IC6 - APW7085 AN66L
                  IC5 - APW7085 AN66L
                  IC4 - APM3020P ON53R
                  The two caps are LF 270C
                  The board isnt working long enough for me to track down the 3.3 source. It looks like the IC5 and 6 chips are meant to generate this. Do you think I should just swap those out and see what happens?
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    IC7 is a 1117, I've already seen some fail (especially under thermal stress, and that seems to be the case with the discoloration). Even though I don't think it's the issue, you can rule it out by replacing it (it's a very common part, should be easy to find).
                    IC6 is indeed a DC-DC buck converter so it probably generates 3.3V from a 5V or 12V source. You need to check the inputs of this component, namely VIN (pin 1) and EN (pin 2), to check if it's the source of your problem or not. VIN is probably 12V, so check that when it's not working. EN must be higher than 2.1V for this DC-DC converter to turn on, so check that as well.
                    You could check the same stuff on IC5.
                    • chicago77
                      • Oct 2014
                      • 15
                      Dumb question, but where would I source these parts I can only find the 7085 on ebay and it looks like a 2-3 turnaround on shipping.
                      • chicago77
                        • Oct 2014
                        • 15
                        When the unit is not funcioning both ic 5 and 6 have the same outputs 1-8:
                        12.49, 6.29, 12.10, decaying voltage, 0, 0, 0, 0.
                        I only managed to get pins 5-8 on ic6 while it was working 0, .8, .55, 4.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          Hum… I guess "0, .8, .55, 4" is in fact from pin 8 to 5, since pin 8 is GND so it must be 0V, and pin 5 is LX which is connected to the output inductor, so it must be close to 3.3V.
                          If you have a low-end multimeter the measurement on pin 5 might be slighty off (as it seems to be right now) since it is switching at a high frequency. If you measure after the coil you should get 3.3V.
                          I'm not sure about the pin ordering of "12.49, 6.29, 12.10, decaying voltage" either. Could you check that again?
                          • chicago77
                            • Oct 2014
                            • 15
                            Yup, I brainfarted on 5-8 they are reveresed. That 4volts is 4v before and after the coil I have a fluke 87 which is fairly decent.
                            What I mean by decaying is the voltage starts around 2-3v and goes down as something in the circuit drains.
                            The 12.49, 6.29, 12.1, decaying order is 1-4.
                            • chicago77
                              • Oct 2014
                              • 15
                              I got it to turn on again long enough to take good measurements. These are correct with correct pin labeling this time
                              IC5 1-8 working: 12.49, 5.23, 7.00, 4.30, 4.07, 0.474, 0.797, 0.00
                              IC5 1-8 broken: 12.49, 0.62, 12.10, ~~~, 0.0, 0.0, 0.0, 0.0
                              IC6 1-8 working: 12.49, 5.23, 6.9, 4.32, 3.297, 0.540, 0.802, 0.00
                              IC6 1-8 broken: 12.49, 0.62, 12.10, ~~~, 0.0, 0.0, 0.0, 0.0
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                Pins 5 to 8 at 0V obviously means that those IC aren't producing any output, it's not even trying to switch apparently.
                                Indeed, pin 2 (enable) is low at 0.62V when it should be higher than 2.5V for the IC to be working.
                                Now… Why is the enable pin low? Who knows… Maybe the scaler IC is shutting down, or maybe it is another IC. You would have to use your multimeter in continuity mode (beep) to trace out the enable signal (which probably goes through a resistor).
                                • chicago77
                                  • Oct 2014
                                  • 15
                                  Can you explain how vcc works on this chip because that is also going into the weeds. Is it strange for ic5 to be sitting at 4v I'm wondering if it's shutting off due to over voltage.
                                  • Stephen
                                    MacBook Pro 16" 2019 A2141 Issue (powers on)
                                    by Stephen
                                    Board powers on, holds charge it seems, track pad clicks, display is working etc. When trying to boot it turns itself off and then boots again and repeats. If it stays at GLOBE icon it will not turn off. Customer needs data, enabled THUNDERBOLT Mode, plugged in Thunderbolt cable, but error comes "THIS DISK CANNONT BE UNLOCKED DUE TO AN ERROR" I can't even input a password. Did a soft restore to retain data to see if it will solve any firmware issues. Nothing, I do not want to restore the computer because the customer needs the data, computer stays on completely when at Globe or...
                                    12-06-2023, 03:10 PM
                                  • SONY_E-WASTER
                                    WACOM CINTIQ 24HD DTK-2400 no power.
                                    by SONY_E-WASTER
                                    hello I have a Cintiq 24 hd dtk 2400 manufactured aug 2011.
                                    it has no power. Tested with known good power bricks. The green light on the power brick dims when connected to the Cintiq. this is a WACOM display that takes pen input for illustration and the like.
                                    I dissembled it and located the power input board and noticed a heat damaged component. (see pic)
                                    https://photos.app.goo.gl/87cwnc1mc8Yd1zES9
                                    it is labeled
                                    FR5305
                                    I*R 049P
                                    ZD 85
                                    I did an ebay search...
                                    02-02-2022, 06:42 PM
                                  • ugamazing
                                    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                    by ugamazing
                                    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                    12-17-2024, 07:05 PM
                                  • shahnld
                                    Lenovo legion 5 pro startup issue
                                    by shahnld
                                    Good day Experts
                                    I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                    A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                    And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                    08-24-2025, 12:31 PM
                                  • ahmarzo
                                    Acer laptop battery draining issue
                                    by ahmarzo
                                    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                    08-02-2025, 06:39 AM
