KenMates GlobalTech L17AX
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    I am not even sure who actually makes the damn thing. It is 17", with sound and USB built into the base. Black with silver plastic frame.
    Anyway, good signal for roughly 5 seconds then off with power light still green.
    The power inverter has one United ChemiCon cap, can't remember the specs but since the power light still shows green, I don't think the problem is there.
    The signal inverter is a different story. Two Lelon 470uf 16V, and 2 Lelon 1000uf 16V. They are not bulging are leaking but they are wonderful mint julip barf green Lelon, so I strongly suspect them to be the cause. Only other thing noticable is some solder rosin seep on a few areas of the board but no thing looks loose or dry.
    I was planning on using Panasonic FM for the 1000uf 16V and Nippon ChemiCon KZJ for the 470uf 16V. Those are closest in size to the junk caps.
    Any thoughts or recommendations on the diagnosis or on the choices for replacement caps?
    Many thanks for all the help from you folks.
    Bill
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    Re: KenMates GlobalTech L17AX
    Am I in the ballpark with the proposed replacement components on this beast?
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Should check specs on old ones to be sure. [If you can find them.]
      http://www.lelon.com.tw/index.php?fn=cat&id=12
      KZJ should work but probably overkill. They are way WAY low ESR.
      I've been using Panasonic FJ for the 470uf 16V in those.
      Fairly easy to find on eBay.
      The FM sounds fine.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Let's see:
        There's:
        Low ESR
        Super Low ESR
        Ultra Low ESR
        Super Ultra Low ESR
        and then there's way WAY Low ESR.
        Is that how it goes?
        - Dr Seuss
        • DixiePenguin
          • Mar 2008
          • 77
          • Philippines
          Many thanks!
          Remember:
          Nekkid means you ain't wearin' any clothes,
          buck nekkid means you ain't wearin' any clothes and yore up to sumpthin'!
          • Wizard
            • Mar 2008
            • 2296
            and one more:
            Ultra quantum low ESR (lowest of extremes) = short.
            Cheers, Wizard
