Dell U2312H Repair
  • ilod
    • May 2020
    • 3
    • Israel
    Re: Dell U2312H Repair
    Hey all, got a problem with the same monitor model so just using this thread rather than a new one. When plugging mine it is recognised by the pc, the blue led turns on as well but there's no display at all. After reading this thread i checked the g1084 regulator and it works fine. All caps visually seem ok, no leaking or bulging. Naturally I suspect the led driver however.i can't seem to find it! Is it part of the main power board? (Picture at beggining of thread) i'm attaching a pic of the lcd control for reference.
    I'd appreciate any help in locating it or any other ideas for what could be.wrong. thanks!
    • kmjacks
      • Jun 2020
      I got the same no-blue/orange button light problem intermittently after plugging it in, and it is solved by replacing G1084-33 which seems to be a low-quality part. The 5V is unstable only when the signal board is connected. I almost ordered another power board, until I see this post and tried the 3.3V regulator on the signal board. I also had to replace the burned fuse F802 on the power board. I am not sure but it is possible that the signal board 3.3V line might be powered up by other power networks, and when that failed it caused the ticking sound.
      FYI, the power board schematic can be found here #5 and #7: https://www.badcaps.net/forum/showthread.php?t=94257
      The board can be slightly different depending on the 01M 01N 02M 02N versions.
      • HTR-Informatique
        by HTR-Informatique
        02-09-2025, 06:51 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • jake-b
        dell e6540 boots to black screen (no dell logo)
        by jake-b
        good morning all,
        i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
        01-08-2024, 10:29 AM
      • Swedishpower
        Dell G3 15 3500 black screen
        by Swedishpower
        Hello
        I have search everywhere for a solution for my problem, but cant find it anywhere.
        When I was away to trow some garbage i always look in the electronic bin.
        and this time i find a laptop.
        Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
        the lamp for charmig is white.
        Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
        but no Dell logo.
        I tryed with a hdmi cable to another screen, still black.
        I started to search solution and tryed...
        07-06-2025, 06:18 AM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
