Lenovo Thinkvision LCD: fix or cheap retrofit
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    As mentioned in another thread, I have this broken 20.5" or so LCD. There was a bad cap that I replaced but apparently fried the backlight somehow when putting it back together - when I buttoned up and powered on, one of the driver transistors gave up the magic smoke.
    I removed that transistor (a SOIC8) and replaced with like but the monitor would not come up any longer - it stays black.
    Now I have two ways to go, wondering what people thought of each:
    Option 1 - Continue pursuing fixing the CCFL driver. I'm at a loss why the CCFL driver would stay dead now, could I have possibly destroyed the oscillator IC (OZ960GN) or something else likely is causing it to stay in shutdown? I'm getting about 20V input into the CCFL driver and the rest of the electronics appear to be on - the power switch will toggle the green LED. I will need to see if hooking up to VGA will stop it from going to sleep mode but it probably does that fine too.
    I tried sticking a scope on the output of the switching transistors and they don't appear to toggle when powering on. Looks like an H-Tree output driver that drives all 6 transformers in parallel.
    Option 2 - Do away with the CCFL and mod to LED. What I'm wondering is if I get a LED strip that's too long for the LCD, can the LED strips be cut easily/safely? As it's not a common size, I likely will have to hack an LED strip to fit. Also what happens if I get a strip that's too short, obviously I'll get some dark spots on the sides but how bad is it? Seems like I will need to get 6 strips of some combination to fully populate this monitor and that's starting to get a bit pricey for custom lengths...
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • ttmi100x
    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
    by ttmi100x
    Greetings everyone,
    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
    Upon closer inspection...
    07-31-2024, 06:36 PM
  • osrex
    LED DRIVER KEEPS DYING
    by osrex
    Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
    i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
    i have no datasheet at all for the LED lights, all i have is its length.
    long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
    as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
    05-05-2025, 03:36 PM
    LENOVO ThinkCentre M91p + ThinkVision LT2252p ThinkCentre M i5-2400 Specification for Upgrade or Repair
    This specification for the LENOVO ThinkCentre M91p + ThinkVision LT2252p can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M91p + ThinkVision LT2252p boardview and ThinkCentre M91p + ThinkVision LT2252p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
    09-12-2024, 03:36 PM
    LENOVO ThinkStation P330 + ThinkVision P27q ThinkStation P i7-8700 Specification for Upgrade or Repair
    This specification for the LENOVO ThinkStation P330 + ThinkVision P27q can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkStation P330 + ThinkVision P27q boardview and ThinkStation P330 + ThinkVision P27q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
    09-12-2024, 02:15 PM
