LG E2240S changes to stand by
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Hi, i have an LG E2240S 22" LED monitor with a defective firmware i think.
    When i turn on the monitor i see the LG logo and a "no signal detected" warning, completely normal as i haven't connected the VGA cable, the image looks sharp and perfect, but as soon as i connect a signal (doesn't matter the source resolution or whatever) the monitor seems to go into sleep mode, strangely if i connect a VGA cable and a DVI adapter even without connecting it to a computer i get the same result.
    Power supply and voltages seem OK, even tested the monitor with a different PSU with no luck, control board looks fine, no bulged caps or overheated components, according to the service manual it's possible to reset the internal config but i'm unable to access at the control menu, the monitor won't respond to the key combination.
    I have checked the components up to the raster chip, nothing wrong with the passives so as a last option i think a corrupted firmware seems to be the culprit, i have located a download link, but it's in Russian an requieres registration with a Cyrillic captcha.
    http://**************/dump/mnt/lg_e2.../130-1-0-20553
    Does anyone have a dump of the flash U403? suggestions?
    Thanks in advance.
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
    by momaka
    03-15-2023, 10:17 PM
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    Yesterday, 04:45 PM
  • soso technician
    LG monitor ips226v-pnx firmware need
    by soso technician
    hi...lg monitor is dead...it seems to have corrupted firmware...because it is assembled in my country it may have different model name around globe...i will send pictures of mainboard,lables and dump firmware that i extracted from faulty board with name old.bin...if you have exact board (its common on diferent lg monitores) please share it...thank you.
    ips226v
    EAX63330406(0)
    110527 D.ZH
    it has 25X20BW eeprom...
    03-21-2025, 06:01 AM
  • ram128m
    LG CE2742VA monitor firmware
    by ram128m
    I have an LG CE2742VA monitor but can't find the firmware. I found a similar model but can't
    buy points to download
    11-29-2024, 02:37 AM
