Dell E1909Wb
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Dell E1909Wb
    Came with PSU problem, fixed.
    Now monitor displays only random screen e.g RGB, White, Black like it is calibrating colors. VGA pins are ok.
    What could be the problem?
    Thanks in advance.
  • 1supertech
    • Apr 2012
    • 384
    Re: Dell E1909Wb
    Check for bent pins on your VGA cable or DVI
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Re: Dell E1909Wb
      All pins are good.
      Looks like burn in mode, can't enter to service menu to turn off.
      Interestingly sometime display works, all factory reset done but after restarting monitor display goes to same effect.
      • 1supertech
        • Apr 2012
        • 384
        Re: Dell E1909Wb
        Pictures of power supply and mainboard would help top and bottom of each board
        • Borse2008
          by Borse2008
          • There’s
          07-15-2025, 04:55 AM
        • spike3333
          Dell 3008WFP monitor cycling colors after repair
          by spike3333
          I have a Dell 3008WFP monitor that I disassembled to replace any bad capacitors. After reassembly, the monitor turns on but immediately starts to cycle through simple colored screens; red, yellow, blue, black and white. From my internet search it appears that the monitor has entered a "burn in" mode. I tried all the different button push combinations that were recommended to enter a service menu but none worked. My question is, could this be caused by a hardware issue; an improperly seated connector or something else. Does anyone else have any experience with a...
          08-12-2021, 09:47 AM
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Jesus Coder
          Issues Reviving Old Dell 2408WFPb Monitor
          by Jesus Coder
          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
          06-25-2023, 02:33 PM
        • Themutantrat
          what pins i need to short to power on the Dell XPS 13 9315 clamshell?
          by Themutantrat
          Does anyone know what pins i need to short to power on the Dell XPS 13 9315 clamshell? I have just the main board and I would like to get into the BIOS to enable boot on AC. Can anyone help me?
          07-27-2025, 10:23 PM
