2 seconds to black samsung syncmaster 931bw
  • momceras
    • May 2016
    • Portugal
    Hi electronic geeks,
    I have a syncmaster 931bw with th "2 seconds to black" synthom.
    Replaced 4 caps hopping that problem be fixed that easy, but not.
    Since I don't have experience with this problem I was hopping the you guys could point me some directions. I was looking for the next step replacing the inverting but it will take too long to arrive (4 weeks aprox). Meanwhile should I try anything else ?
    Re: 2 seconds to black samsung syncmaster 931bw
    I would check the High Voltage windings resistance of the inverter transfomer, and also make two test lamps: https://www.badcaps.net/forum/showthread.php?t=19987
    Please also upload good clear straight shot pictures of the bottom side of the board.
    • momceras
      • May 2016
      • Portugal
      Thanks budm,
      I have tried with other lamps with same result. I ordered the inverter today expecting to get it in 3, 4 weeks. Also have resoldered (forgive me if this is not english) some of the contacts on the bottom side. Since theres is an image, even for few seconds, and there is image I supose the problema would be on the power board. I pointed a flash lighht and I can't see any image.
        09-07-2024, 05:50 AM
      • soopacrucial
        Samsung Syncmaster 740BF repair
        by soopacrucial
        Hi folks,
        I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
        Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
        10-29-2024, 02:40 PM
      • eigma
        Samsung UN40H5003 boot loop every ~8 seconds
        by eigma
        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
        Main board: BN94-07592P / BN97-08922R...
        11-20-2024, 10:31 PM
        09-06-2024, 11:40 PM
