LG IPS237L ... image retention, get pink, ...
  • saronno
    • Jan 2012
    • 57
    I have some strage issue in a LG IPS237L.
    As you can see I have persisten image,
    sometimes it get pinkish
    and on the left part of the panel it looks like
    there are "missing lines" ... the last issue is very difficult
    to catch with the cam.
    Of course I just checked the lvds cable.
    These issues are present with all the inputs (2 HDMI and 1 vga)
    and whatever source you use (bluray, pc, laptop) ... so it is
    something the board or on the panel.
    have you ever had any issue like that?
    TIA
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG IPS237L ... image retention, get pink, ...
    Delete.
    • saronno
      • Jan 2012
      • 57
      Update: I have managed somehow to solve the color problem (It doesn't get pink anymore .. substantially reconnecting all the cable), but a little problem have remained:
      I put a totally blank image on the monitor and I don't get a full blank image in the last
      10 cm on the left. If you check carefully, you have a pattern with one line of pixel fully
      blank and another greenish .... if you move to the right, the greenish line fade to blank
      (in other words it's not a net transition, but a slow change to blank).
      I also check the flex connectors that go directly on the matrix putting some pressure on
      the glued connection and also tried to put pressure on the driver ... nothing.
      • saronno
        • Jan 2012
        • 57
        Good one:
        Bad one:
        • saronno
          • Jan 2012
          • 57
          This german user seems to have a similar problem on the same model:
          http://extreme.pcgameshardware.de/mo...-ips-237l.html
          and also this polish guy:
          http://www.elektroda.pl/rtvforum/topic3183348.html
          • saronno
            • Jan 2012
            • 57
            same problem also here ...
            http://www.elektroda.pl/rtvforum/topic2889170.html
            It seems a pretty common issue with this model.
            • saronno
              • Jan 2012
              • 57
              Anyway, thinking about it, I suppose that the voltage
              level on the selected rows is not good enough and so,
              the transistors don't open completely .....
              so, when you apply the pixel by pixel tension (column)
              you can't charged (and discharge) completely the cell.
              I image that the row has its own resistance and that
              in the first part the voltage is good enough to open the gate
              of the transistors ....but going from right to left
              the voltage is lesser and lesser and so those gates don't
              open the transistor completely...
              Solution? Raise up the voltage feeding those rows ...
              I check tha panel datasheet ... if I am right it's not
              a main board problem but a problem on the pcb of the panel.
              Very difficult to repair (it's very easy to do a damage) .... but maybe not impossibile.
              • saronno
                • Jan 2012
                • 57
                With a VDD of about 12V
                is a VCOM of 4.2V a bit too low?
                Is it the probable cause of image retention?
                If so, since the is no pot to adjust it ... is it programmable
                from a secret menu ?
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                • Jaime Morillo
                  Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                  by Jaime Morillo
                  Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                  The TV was stuck on the logo and I couldn't access the update menu.
                  I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                  The image result was good, but the image is inverted.
                  The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                  Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                  08-18-2025, 11:38 AM
                  Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                  This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                  09-06-2024, 09:30 PM
                • dicky96
                  HP Elitebook Screen blank - backlights but no image
                  by dicky96
                  Hi guys
                  I'm trying to fix this laptop screen
                  Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                  OK so I have the original screen which works but has lines across the bottom quarter of the screen
                  I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                  04-28-2021, 07:30 AM
                  HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                  09-06-2024, 10:56 AM
