Two Dell E 173 problems
  • johnboy183
    • May 2008
    • 119
    I now have 2 dell monitors with the following problems (posted on one earlier but no resolution).
    The E173FPf comes on dark and takes several minutes to lighten up and stays fine until it goes to sleep and then the same pattern happens.
    The other (E173FPt) comes on quickly but the display is dim and has an overall yellowish hue. I have exchanged the two screens and the problems remain the same in each monitor indicating a powerboard fault in each and not a display or backlight failure. The boards look fine with no bulged caps.
    Any help would be very appreciated.
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Caimano
    Problems extracting from Dell Bios Update.Inspiron 3793
    by Caimano
    I am trying to repair a Dell Inspiron 3793 which has problems with start up, no battery charging and fan not running. I believe the Bios (probably the EC Region) is corrupted.
    The board is FDI45-LAJ091P REV 1.0 A00
    Processor i7 1065G7 with GPU
    This MB has 2 Bios Chips (one 8MB and one 16MB chip).
    I am trying to reload a new Bios with clean ME region, new main region and new EC region.
    I attach the dumps of the 2 chips.
    I successfully used ME analyzer to identify ME, PCH and PMC versions and used Flash Image Tool to install ME, PCH and PMC cleaned regions....
    05-04-2022, 11:19 AM
  • stakrzysiu
    Dell Vostro 15 5501 BIOS Problems
    by stakrzysiu
    i have here a Dell Vostro 15 5501
    REG Model: P102F
    SN: 1WD5103
    there is a problem that it shows screen after 1 min.
    Is this caused by me?
    Can someone clean me for me? Then i will try.
    Thank you very much
    Best regards...
    01-25-2025, 05:36 AM
  • F R 2568
    Dell Latitude 5420 does not start (no post) need help to find the reason why
    by F R 2568
    Hello all,
    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
    If the laptop is only connected to the AC adapter (battery removed):
    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
    The power/battery...
    01-08-2025, 05:45 AM
  • diamon
    Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
    by diamon
    I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
    Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
    Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
    Pictures of these boards:
    Dell Latitude 5520 https://www.ebay.com/itm/256052956663
    Dell Latitude 5530 https://www.ebay.com/itm/125844181534
    Dell...
    02-28-2024, 12:51 PM
