Benq FP547 (or Q5X3), power on but no image and backlight
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This old 15" monitor detected VGA signal and powered on accordingly, but there was no backlight and no image was formed on LCD. I thought that it was a typical inverter problem, but the absence of image on LCD misleaded me at first.
    No bulging caps and ESR OK. I get schematics. There's 16V for inverter, 3.3V too, but not the 5V for panel. Then I discover that PF751 is actually a fuse! It really looks like a ferrite / coil! But after unsoldering I can read "bel MS 2A" underneath. It's a 2A / 125V fuse and it's open.
    DC-DC IC781 MC34063ACN seems fine. I just detect broken solder joints on 2 inverter transistors (Q759, Q760, 2SC5706), due to repeated heating-cooling cycles over years. Ressolder all 4 transistors on inverter, replace fuse with a 2A / 230V one and it works again.
  • Attila Jamilov
    Which fuse is responsible for backlight on Lenovo Thinkpad T14 Gen 3
    by Attila Jamilov
    I upgraded display from HD to UHD recently, and I think I did everything right, battery was disabled in BIOS, and removed, yet the screen has no backlight. Both the old and new display behave the same way. I checked the motherboard and I see the fv1 fuse, and a fv2 spot for a fuse, but it's missing. Does anyone have any information on whether fv2 is responsible for backlight, or why it's missing? There's a schematic posted somewhere on this forum, but I can't view it as I don't have the hardware right now, since the laptop screen is broken and I run Linux.
    Also from further search...
    04-20-2025, 10:02 PM
  • Salem Aboshala
    820-00138-A got image but no backlight
    by Salem Aboshala
    Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
    I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
    History: my laptop backlight stopped working without any reason.
    Symptoms:
    I have image on screen using my flashlight.
    I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
    Keyboard backlight still working and can be adjusted normally.
    Since two days I tried to follow all similar...
    06-11-2024, 03:02 PM
  • zaurus81
    Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
    by zaurus81
    This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
    The board is equipped...
    01-16-2025, 03:54 AM
  • Constantinos
    Macbook Pro A2442 820-02098 No image but has backlight
    by Constantinos
    Hi all
    I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
    He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
    Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
    Obviously, he decided against this and gave it to me so that I could have a crack at it.
    From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
    08-24-2024, 09:48 AM
  • ajgae
    HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
    by ajgae
    Hi everyone!
    First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
    03-06-2025, 09:53 AM
