Dell ST2421L Shadow in screen.
  • soulripper
    • Aug 2011
    • 22
    Hi, found this baby works great in gaming & Movies. Using HDMI Gold tip. Has a shadow on bottom closer to left side of Monitor . can this be Fix.
    Is LED Monitor have not open to check it out inside yet. Waiting for Advice.
    Key specifications
    Screen size 24 inch
    Resolution 1920x1080 1080p true HD
    Pixel density 92 ppi
    TFT panel type TN
    Brightness 250 cd/m²
    Contrast ratio 7,000,000 : 1
    Total response time 5 ms
    DVI Ja
    HDMI Ja
    [/URL][/IMG]
  • R_J
    • Jun 2012
    • 9558
    Re: Dell ST2421L Shadow in screen.
    I suspect its a edge lit backlight with one or more bad led's, panel would need to be disassembled to confirm it.
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • ChristianBr01
      Dell 34 inch U3419W Monitor with thin stripes on partial screen
      by ChristianBr01
      I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
      This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
      This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
      Does someone have seen this before?...
      05-23-2025, 06:06 AM
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Swedishpower
      Dell G3 15 3500 black screen
      by Swedishpower
      Hello
      I have search everywhere for a solution for my problem, but cant find it anywhere.
      When I was away to trow some garbage i always look in the electronic bin.
      and this time i find a laptop.
      Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
      the lamp for charmig is white.
      Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
      but no Dell logo.
      I tryed with a hdmi cable to another screen, still black.
      I started to search solution and tryed...
      07-06-2025, 06:18 AM
    • turmix
      AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
      by turmix
      Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
      The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
      At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
      During another reassembly, I made a mistake, and...
      01-29-2024, 03:48 AM
