Looking for advice on the repairing of a hitachi commercial plasma monitor cmd 4201 currently cycling off after power up.Shot gun repair effort so far ,just replacing suspect board x and y substain s. Power supply board .I have repaired it several times before luckily. Want to do a more complete evaluation of my problem. The power supply I assume is cycling because of I believe that the Y substain is bad. Can I test the power supply board to rule out,problems on it. Should the power supply supply vs va for the substain boards with them unplugged,. Will I get the voltages before it cycles off or not. I have a trouble shooting flow chart that suggests a sequence of tests for narrowing down the problem,. So is anybody familiar with these monitors,it does not have a tuner. Thanks joe
Hitachi plasma monitor cmd4201 troubleshooting
by Phil StasikPioneer Pro-FHD1 Elite. Failure to power on.
I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the... -
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by Rick_1234Good evening, gentlemen.
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... - Loading...
