Problems with Samsung 740N monitors
+ More Options
Posts
  • mladen82
    • Mar 2009
    • 39
    • Montenegro
    #81
    Re: Problems with Samsung 740N monitors
    Originally posted by warragul
    mladen82, am I right in assuming that the FETs are the small SMDs on the underside of the board? Can't find my magnifying glass. If so the fuse doesn't last long enough for it to get warm.
    yes, they are smd, 8pin
    i think they have label 4502C
    http://www.alldatasheet.com/datashee.../AF4502CS.html
    check these for shorts
    • PlainBill
      • Feb 2009
      • 7034
      Thanks again for the assist.
      I'm a little puzzled, though.
      This is the first SMPS I've encountered with a fuse in the output. These power supplies usually rely on the oscillator stopping if the load gets too much.
      The Topswitch chip manufacturer's suggested circuits I've found don't have output fuses either. Some sort of effect of the sort of load it's driving, perhaps?
      The fuse isn't there to protect the power supply, it's there to prevent damage to the inverter. Note that the component number for the fuse is in the same series as the rest of the inverter, not the power supply.
      To elaborate, let's say power supply components use '100' series numbers. Caps start at C101, resistors at R101, fuses at F101, etc. The inverter might use 800 series numbers (C801, R801, and F801, etc). It's not an output fuse for the power supply, it's an input fuse for the inverter.
      PlainBill
      • EGuevarae
        • Nov 2008
        • 1336
        ..... This is the first SMPS I've encountered with a fuse in the output. ....
        I see it as the fuse at the inverter's input, not at the PSU's output (I think of it as the fuse on the AC input of the PSU). If you had a monitor where all the three boards were separated (Video/signal, PSU & inverter boards), you won't find a fuse on the output of the PSU for the inverter : you will find a fuse on the input of the inverter board. Some PSUs I've seen have fuses (not the tube/glass ones, but the ones like small caps) right before the DC output to the signal board. That too can be considered either a fuse at the PSU's output or at the VBoard input ...
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • mopar-mechanic
          • May 2009
          #84
          i'm new to this and gonan give it a go, thanks guys!
          I'll let you know how it works out, just ordered the caps and fuse from digi-key, what a great place that is!
          • beanrocco
            • May 2009
            #85
            This post was really help full in fixing my Samsung 930B. I had the same defective power/inverter board. I changed the 3x820uF by 2x1000uF + 1x470uF for approximately the same total amount of capacitance 2460uF. I also had to changed the C301 pico fuse. I only had in stock the SMT version so I removed the defective one and solder the SMT fuse between the 2 holes on the bottom side of the PCB.
            The Monitor now work perfectly. It was an 8$ Canadian fix and 1 hour of my time.
            • mopar-mechanic
              • May 2009
              #86
              IT WORKS!!!Awesome guys, thanks for the input. My first lcd repair, all went well! DIGI-KEY ftw.....
              • EGuevarae
                • Nov 2008
                • 1336
                Glad to know of a success. It feels good to repair something that you think is going to head right to the dumpster, right?
                • GeForce GT1050
                • DSpawnZ
                  • May 2009
                  • 20
                  • Argentina
                  #88
                  Hi guys. Greetings from Argentina. First post here.
                  I have a 740N monitor that stopped working. Blue power led on, no image, no inverter.
                  I've found the famous three 820 uF caps bulged and changed them to 1000 uF.
                  Now the blue led flashes very fast and PS makes noise as fast as the flash.
                  I try to measure the output voltages and they are way high. 8V at the 5.1V part and 18V at the 13V part.
                  Can you help me with this? Sorry for my english
                  Thanks a lot!
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    Thanks a lot!
                    See post #85 (up) - you changed 2460uf for 3000uf. Maybe there's where your problem lies.
                    And welcome to the forums.
                    • GeForce GT1050
                    • mladen82
                      • Mar 2009
                      • 39
                      • Montenegro
                      #90
                      also check optocupler 817
                      • fzabkar
                        • Mar 2009
                        • 772
                        Here is a 4-part service manual:
                        http://service.eclubthai.com/new/mon...940N.part1.rar
                        http://service.eclubthai.com/new/mon...940N.part2.rar
                        http://service.eclubthai.com/new/mon...940N.part3.rar
                        http://service.eclubthai.com/new/mon...940N.part4.rar
                        Here is another source:
                        http://www.eserviceinfo.com/download.php?fileid=36789
                        http://www.eserviceinfo.com/download.php?fileid=36790
                        http://www.eserviceinfo.com/download.php?fileid=36791
                        Disassembly/reassembly instructions:
                        http://www.eserviceinfo.com/download.php?fileid=28685
                        • ethernet
                          • May 2009
                          • 11
                          #92
                          Greetings to all
                          I have changed 3 820uf capacitors and 3A fuse and now the CCFL lamps start for a second and they turn off again. After two seconds they startup again for a second and turn off again. I checked 13V line and it reads 18V and just as the lamps turn on for a second voltage drops to 13V and comes back to 18V when the lamps turn off. What can be the problem?
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Originally posted by ethernet
                            Greetings to all
                            First of all, welcome to Badcaps.Net
                            Post a picture of your board to see if we can see something suspicious. You might have more bad components in there. Post also brand/series/ V rating and capacitance rating of remaining caps. That would help you to get the info you need.
                            • GeForce GT1050
                            • Wizard
                              • Mar 2008
                              • 2296
                              #94
                              740N use 13V supply. your feedback regulation is screwed up. Change more capacitors in the rest of PSU and see.
                              Cheers, Wizard
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Cheers, Wizard
                                Yep. Checking my notes I found that all the 17/19" LCD units from Samsung that I have checked used 13v. Again, post cap info and/or pics.
                                • GeForce GT1050
                                • ethernet
                                  • May 2009
                                  • 11
                                  #96
                                  You guys here are quick. Didn't expect a reply so soon.
                                  I replaced all caps again and no luck. I put in 3 CapXon 25v 1000uf. I did that on my friends monitor and his is working like a charm. Mine just wont stay on. Itried 2 1000uf + 1 470uf and the problem remains.
                                  1. I turn the monitor on,
                                  2. Big green transformer starts to make hissing sound and 13V line reads 18,3V
                                  3. Lamps go on for a split second, 13V line reads 10-13V
                                  4. Big green transformer stops making noise and lamps turn off 13V line reads 18,3V again
                                  5. After two seconds transformer starts making hissing noise and we are back at step 2. and so it goes round and round.
                                  And i tried to messure voltage on the big capacitor (450V) and it reads 750V!! If the capacitor is rated at Max 450V how can it read 750V?
                                  Can this be a faulty transformer or is it something else?
                                  Here is the pic you requested
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    #97
                                    Do not power up again, you will kill the HV section on the inverter! Time to disconnect the link to the lamp inverter so you can keep troubleshooting the feedback section.
                                    This feedback usually tap the important voltage which is 5V on this board, I do see a microamp regulator feedback (is that a TL431 in there above the optisolator IC?). Measure that 3 legged device and one of pin should be 2.5V if not, either resistor network or that device is bad. Ohm all the resistors.
                                    Are you using low ESR with high current ripple capacitors?
                                    Remember, always measure: cold side voltages with cold ground or hot side voltages with hot ground, not cross each other when where to put DMM probe on the particular ground plane in this SMPS.
                                    Cheers, Wizard
                                    • ethernet
                                      • May 2009
                                      • 11
                                      #98
                                      Still no luck,
                                      i detached the 3A fuse so the inverter wouldnot startup a did everything you said Wizard. All resistors check out, and yes, on tl431 there is 2.49V. I am using low ESR capacitors and i still dont have a clue what is wrong. Do u have some other advice i could try? I would hate to throw away this monitor for a problem that maybe cost a few bucks.
                                      I noticed that voltage dropped to 16.30V when i removed the 3A fuse. Is this information helpful?
                                      • Wizard
                                        • Mar 2008
                                        • 2296
                                        #99
                                        Still not good. What is your reading on 5V while other 13V is at 16V?
                                        Cheers, Wizard
                                        • Wizard
                                          • Mar 2008
                                          • 2296
                                          #100
                                          I was busy eating, now I can think and talk,
                                          Keep fuse disconnected for now.
                                          while checking the 5V as I asked, ohm the rest of resistors have you? Some of the circuit better unsolder one end of resistor and recheck. I know some places is SMD resistors makes it bit tricky. What about the small capacitor in the hot side of SMPS?
                                          This filters the hot side DC supply for the SMPS IC.
                                          Also I check stuff in the hot side resistors as well.
                                          Remember to discharge the main capacitor with piece of 100K resistor after power cord is unplugged for your safety if working/troubleshooting this.
                                          Cheers, Wizard
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
