Problems with Samsung 740N monitors
+ More Options
Posts
  • grade
    • Jun 2011
    #261
    Re: Problems with Samsung 740N monitors
    my samsung 740n is dead
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Fuse here;
      Mann-Made Global Warming.
      - Dr Seuss
      • cynz
        • Jun 2011
        • 5
        #263
        Tanks for all the guys here. I got really helpful info here during the DIY for repairing my Samsung 740B.
        Right now, I got my LCD work and go well.
        What I did is:
        a) replaced three 820uf 25v caps beside the transformer
        b) unsoldered the green small 3A fuse beside a 820uf 25v cap, then solder a solid wire into it.(as i don't have any alternation one in hand, but it is risky)
        As a result, bad caps always play the key role and induce the fuse burnt.
        New discovery: OEM used the same model power board in IBM L171p LCD, which means samsung made PBD for IBM monitor as well.
        • jetadm123
          • 2169
          #264
          What I did is:
          Hopefully, you'll reconsider and use a real fuse versus a plain wire. Fuses are used for a reason.
          • enghijjawi
            • Jun 2011
            • 10
            #265
            thanks for all guys here
            I have SyncMaster 730B, its board model IP-35135B, for few days looking for its schematic
            please if one have service manual for 730B
            i download service manual for 740N and its schematic different and not match.
            • PlainBill
              • Feb 2009
              • 7034
              Service manual here.
              PlainBill
              • enghijjawi
                • Jun 2011
                • 10
                #267
                Sorry to bother, I'm new to the site
                I hope it helps me find a way to download the file where the site is in Hungarian (translate it to english through google translate) and tried to register but only rejected a joint invitation from someone Active
                I hope that helps me
                Accept my profound thanks and appreciation
                • PlainBill
                  • Feb 2009
                  • 7034
                  The site is located in Poland.
                  Menus are in Polish and English.
                  Registration is not required.
                  Steps:
                  1. Click on link.
                  2. Click on blue arrow next to Samsung 730BF. A new page opens.
                  3. Click on Get Manual upper left part of page.
                  PlainBill
                  • enghijjawi
                    • Jun 2011
                    • 10
                    #269
                    Hi, PlainBill
                    Thank you for your help and your answer
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Hi, PlainBill
                      Je vous en prie!
                      PlainBill
                      • celtronics2011
                        • Sep 2011
                        • 12
                        #271
                        Samsung LCD 740nw Led flashes and no picture
                        Hello ... The problem I have with my monitor is that when connected to the grid is turned on the power button is blinking and not showing me anything on the screen even in a message that has no connection to the pc. Thanks & Regards .........
                        help
                        • PlainBill
                          • Feb 2009
                          • 7034
                          help
                          1. Do not post pictures inline. Use 'Manage Attachments' - below the text entry area.
                          2. Do not use pictures you found on the internet. The first one has obviously defective caps. The second shows only a fragment of the power supply.
                          PlainBill
                          • celtronics2011
                            • Sep 2011
                            • 12
                            #273
                            hello apologies
                            Some possible solutions
                            where to begin to test
                            all coils are in perfect condition
                            status as verefico (dm0465)???
                            thanks
                            • PlainBill
                              • Feb 2009
                              • 7034
                              hello apologies
                              thanks
                              Start by replacing all the electrolytic caps except C105? (the big yellow one). At least two of them are defective.
                              PlainBill
                              • celtronics2011
                                • Sep 2011
                                • 12
                                #275
                                problem solved
                                capacitors were only 10v/1000 microfariados
                                thanks
                                • jossuez
                                  • Sep 2011
                                  • 10
                                  #276
                                  Hi everyone!! I have a problem with my Samsung 743NX
                                  https://www.badcaps.net/forum/showthread.php?t=16559
                                  Any suggestions?? Thank you very much!!
                                  Joss.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Joss.
                                    Three suggestions:
                                    1. Stop hijacking threads.
                                    2. Don't double post.
                                    Either of these will cause some people to ignore you.
                                    3. Follow Rtech's advice.
                                    PlainBill
                                    • jossuez
                                      • Sep 2011
                                      • 10
                                      #278
                                      Three suggestions:
                                      PlainBill
                                      Oh i'm so sorry Thanks for the suggestions, I'll do.
                                      Joss.
                                      • jmcasa
                                        • Oct 2011
                                        #279
                                        Hi
                                        I'm new here and I'm looking for a solution for my 740. After I turn on the monitor it only shows the image for 1 second but blue led is on. The problem is that my power board is not exactly the same as posted here, my power board is BIZET-17A, REV:1.0A 2005.1.20 BN44-00123A. Components are not the same, I don´t have mosfet, caps 820, pico fuse... and design is different.
                                        Anybody can help me?
                                        Thanks in advance!
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #280
                                          1) 2 seconds to black can be
                                          a) bad caps
                                          b) bad inverter transformer
                                          c) bad ccfl and/or wiring
                                          All are discussed in more detail in posts #13 and #14 at
                                          https://www.badcaps.net/forum/showthread.php?t=10419
                                          Also please read misc suggestion #1.
                                          --- begin sig file ---
                                          --- end sig file ---
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
