Problem with Samsung 743NX
  • jossuez
    • Sep 2011
    • 10
    Hello everyone!
    I have a problem with my monitor Samsung 743NX, at first the monitor switched on, show image for 2 seconds and then the screen goes black, no image. Only the power button stayed blue on....
    What I did was change 3 capacitors (820 μF 25v) and and the monitor turns on perfect, BUT.....starting the computer will appear different colors and the image fades and turns black, and at other times only shows the error in the bottom.
    Is very strange, sometimes I can use it perfectly and shows no failure.
    Some videos of the failure:
    Bottom error:
    http://www.youtube.com/watch?v=LOr8si06slY
    Fade Image:
    http://www.youtube.com/watch?v=RkKzFubeAho
    Strange Image:
    http://www.youtube.com/watch?v=yMlZUm_rOiw
    Appreciate any suggestions that I can do to remedy this failure!!
    Thanks for reading the Thread, and sorry for my spelling.
    Greetings!! Joss
  • Rtech
    • Jul 2010
    • 1095
    Re: Problem with Samsung 743NX
    First thing to do,is take off the lead between the screen and the Logic Board, and then put it back ensuring it is seated correctly.
    • jossuez
      • Sep 2011
      • 10
      Hi, I did what you suggested, but the problem continues, now the problem happens when "turn on" the monitor, but after a while, the problem disappears. It's like something needed to be heated to remove the problem.
      Any other suggestions? Thank you very much!
      Sorry for my bad English lol
      Greetings! Joss.
        09-07-2024, 05:50 AM
      • howardc64
        Samsung UN55JU650DF network/streaming problem
        by howardc64
        Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
        This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
        07-09-2025, 12:44 PM
      • alro7779
        Samsung UN55MU6103F video problem; has colored stripes on the display
        by alro7779
        Hello, everyone!
        A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
        09-27-2025, 11:29 PM
      • ioanban
        samsung UE49MU6120KXXU image problem
        by ioanban
        Hi guys,
        I have a samsung UE49MU6120KXXU with a flickering problem and some lines on the screen.
        I have looked around the forum but i didn't manage to find a solution to my problem.
        I've already tried to clean the cable strips but nothing changed.
        I've atached some pictures with all the boards and a video with the problem for you to get a better idea.
        https://youtube.com/shorts/QNxt4RIdJ0g?feature=share
        Regards,...
        08-26-2021, 09:12 AM
        09-06-2024, 11:40 PM
