Syncmaster T190 - a headache
+ More Options
Posts
  • 50AE
    • Aug 2015
    • 5
    • Bulgaria
    Hello to everyone,
    I recently bought a used display – Samsung Syncmaster T190. When I brought it home and plugged it into my computer, I found out it's completely dead:
    -No backlight
    -No image
    -No power indicator LED glowing
    -No reaction from the touch sensor button or any button at all.
    So I decided to try repairing it. I have repaired a few LCD screens in the past and a few SMPS by recapping them, so I thought “why not”?
    I took off the power supply board and examined it. There were two bumpy leaky capacitors visible. I took them off, measured their ESR, it was 1.1R and 1.8R.
    I decided to replace all capacitors, even those on the processor board. I used Fujicons low ESR series 105C, except on a place where 3 caps where in parallel. Because I had much higher voltage Fujicons for there and they couldn't fit. I decided to solder 3 no-name brand ones.
    When I plugged everything like it was and turned the power on again – nothing happened. It was dead again, the same way it was before, when I bought it.
    Then I measured the voltages coming from the power supply board to the processor board:
    - 15,8V measured on the +14VDC rail
    - 5,2V measured on the +5VDC rail
    I also examined the processor board and its datasheet. The processor's name is SE758MRH-LF.It turned out, it has three local regulators: 1,8V ; 3,3V ; 3,3V. They are feeded from the +5VDC rail. It turns out, the first local regs 1,8V and 3,3V are feeded only when a mosfet switch saturates when its GATE connected to KEY1 pin goes to positive 3,3V
    I tried measuring all the local regs with the KEY1 pin to 3.3V and the voltages are good. But I also found out, that the power LED never turns. I even soldered a local LED near the Vled out pin, but I had no result.
    On the power board, there is a ON/OFF pin that when connected to PIN1, turns the backlight on, but no image outputs. Also, the power sensor button works in this situation. I also tried connecting ON/OFF to PIN1 and 3.3V – still only the backlight exists, but I get no image.
    So, in summary:
    -The voltages measured with a DMM measure okay, except for the 15,8V on the +14VDC rail.
    -The power LED doesn't turn on.
    -The ribbon cables seem okay.
    -The CFL work
    -The ON/OFF connected to KEY1 brings the backlights
    And I have some things to try before going desperate about it:
    -Measure each voltage rail with an oscilloscope
    -Change the no-name parallel new caps I put with low esr fujicons.
  • addytzu123
    • Mar 2013
    • 54
    • ROMANIA
    Re: Syncmaster T190 - a headache
    See the attached service manual, try to use the troubleshooting guide.
    In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
    • addytzu123
      • Mar 2013
      • 54
      • ROMANIA
      See also the wiring diagram...
      • 50AE
        • Aug 2015
        • 5
        • Bulgaria
        Many thanks!
        So judging from the troubleshooting guide, the problem is still in my power supply board.
        • 50AE
          • Aug 2015
          • 5
          • Bulgaria
          I changed the 3 capacitors with Fujicon low ESR and no luvk - still dead. I'm going for the osciloscope.
          • Porto
            • May 2015
            • 109
            • NL
            Good chance some mosfet / driver or diode is shorted.
            • 50AE
              • Aug 2015
              • 5
              • Bulgaria
              With the main board on (KEY1 to 3.3V), I get 50mV of ripple on the 5Vdc line. The other lines seem okay.
              On photo 1, there's the voltage line
              On photo 2, the small peak at the highest ripple amplitude is zoomed at 20us/div
              Photo 3 reveals the ~10 MHz harmonic content, provably caused by the digital circuitry.
              • addytzu123
                • Mar 2013
                • 54
                • ROMANIA
                Have you found a solution to the problem ? I am not sure the PS is at fault here.
                Can you insert 5V from another source (like a bench power supply) into the main board, (monitor''s PS disconnected) and check again the voltage at the local regulators, memory IC's and if the 5V DC is present at the LVDS (CN400 )cable, pins 1 and 7 ?
                • soopacrucial
                  by soopacrucial
                  Hi folks,
                  10-29-2024, 02:40 PM
                • nh2
                  Samsung SyncMaster 215TW buzzing / lightning in power board socket
                  by nh2
                  This is my first post here. I just fixed my first 2 broken displays by replacing broken capacitors (Samsung SyncMaster 226BW, and Samsung SyncMaster 213T). But I have a third one I'm unable to fix, and am eager to fix as well:
                  My Samsung SyncMaster 215TW makes a buzzing / hissing sound when turned on.
                  The sound is louder the brighter the monitor is, e.g. in the "Game" preset is is even louder than in a softer preset.
                  Opening up the monitor and unplugging the small socket cables that run from the power board to the LCD, I can see a small blue...
                  08-31-2021, 02:23 AM
                • rattlesnake
                  Samsung SyncMaster 955DF dim image fix
                  by rattlesnake
                  This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                  To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                  08-12-2023, 07:03 PM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
                • Kyrtapy
                  Syncmaster T220 flashing on and off
                  by Kyrtapy
                  Hi, my monitor started having an issue. While there is a vga or dvi cable connected to the monitor, the screen flashes on and off. If there is no cable connected, it shows the no signal warning without any issues.
                  I tried different cables and nothing helped. I also tried using different monitor with my pc and the monitor was working normal so my computer is not the issue.
                  Last year I replaced two of the capacitors because they were leaking and the monitor was having trouble starting up and it fixed the problem, but now, no leaking capacitors on the PCBs.
                  12-24-2024, 12:21 PM
